Hi All,
I just received my electron, and I’m new to particle community. However, I already have some experience with Arduino and Edison. Because of that, I decided to use my own GPS module instead of buying one with electron.
I looked for asset tracker example, but could not figure out, which are the serial pins being used.
Besides, once I transmit the messages, How do I do to see my data on the cloud?
Please help.
It’s using Serial1 which corresponds to TX and RX pins on the Electron.
https://docs.particle.io/datasheets/electron-datasheet/#pin-markings-
You can see how it’s done using Particle.function() and Particle.puslish() here:
https://github.com/spark/AssetTracker/blob/master/firmware/examples/1_GPS_Features.cpp#L46
https://github.com/spark/AssetTracker/blob/master/firmware/examples/1_GPS_Features.cpp#L90
You could use CLI or Particle Dashboard or your own SSE viewer
And for triggering functions also CLI or this or this or again your own way
