Getting system diagnostic data from user firmware
The system diagnostics feature in Particle Device OS 0.8.0 can make troubleshooting device problems easier.
For example, when viewing a device in the console, you can view the device vitals:
devicevitals
This is periodically updated automatically so you don’t have to worry about it. You can also use the cloud API to request a refresh of the device vitals.
You can also monitor the device vitals event by subscribing to it.
But what if you want to get at some of this information from your user firmware, so you can send it somewhere else, or use it to control things in your firmware?
For example, the Device Key Helper library uses diagnostics to find the last connection error. From this, it can determine if the connection failed because of a keys error and take appropriate action.
Some things like free memory are more easily obtained using the regular system firmware calls like System.freeMemory, but others are only available in diagnostics.
I created a library, DiagnosticHelperRK, to make getting these values easy.
Diagnostic Items
The various items that are available are described in the device vitals metadata.
There’s also the official list in the Device OS source:
typedef enum diag_id {
    DIAG_ID_INVALID = 0, // Invalid source ID
    DIAG_ID_SYSTEM_LAST_RESET_REASON = 1, // sys:reset
    DIAG_ID_SYSTEM_FREE_MEMORY = 2, // mem:free
    DIAG_ID_SYSTEM_BATTERY_CHARGE = 3, // batt:soc
    DIAG_ID_SYSTEM_SYSTEM_LOOPS = 4, // sys:loops
    DIAG_ID_SYSTEM_APPLICATION_LOOPS = 5, // app:loops
    DIAG_ID_SYSTEM_UPTIME = 6, // sys:uptime
    DIAG_ID_SYSTEM_BATTERY_STATE = 7, // batt:state
    DIAG_ID_SYSTEM_POWER_SOURCE = 24, // pwr::src
    DIAG_ID_NETWORK_CONNECTION_STATUS = 8, // net:stat
    DIAG_ID_NETWORK_CONNECTION_ERROR_CODE = 9, // net:err
    DIAG_ID_NETWORK_DISCONNECTS = 12, // net:dconn
    DIAG_ID_NETWORK_CONNECTION_ATTEMPTS = 27, // net:connatt
    DIAG_ID_NETWORK_DISCONNECTION_REASON = 28, // net:dconnrsn
    DIAG_ID_NETWORK_IPV4_ADDRESS = 15, // net:ip:addr
    DIAG_ID_NETWORK_IPV4_GATEWAY = 16, // net.ip:gw
    DIAG_ID_NETWORK_FLAGS = 17, // net:flags
    DIAG_ID_NETWORK_COUNTRY_CODE = 18, // net:cntry
    DIAG_ID_NETWORK_RSSI = 19, // net:rssi
    DIAG_ID_NETWORK_SIGNAL_STRENGTH_VALUE = 37, // net:sigstrv
    DIAG_ID_NETWORK_SIGNAL_STRENGTH = 33, // net:sigstr
    DIAG_ID_NETWORK_SIGNAL_QUALITY = 34, // net:sigqual
    DIAG_ID_NETWORK_SIGNAL_QUALITY_VALUE = 35, // net:sigqualv
    DIAG_ID_NETWORK_ACCESS_TECNHOLOGY = 36, // net:at
    DIAG_ID_CLOUD_CONNECTION_STATUS = 10, // cloud:stat
    DIAG_ID_CLOUD_CONNECTION_ERROR_CODE = 13, // cloud:err
    DIAG_ID_CLOUD_DISCONNECTS = 14, // cloud:dconn
    DIAG_ID_CLOUD_CONNECTION_ATTEMPTS = 29, // cloud:connatt
    DIAG_ID_CLOUD_DISCONNECTION_REASON = 30, // cloud:dconnrsn
    DIAG_ID_CLOUD_REPEATED_MESSAGES = 21, // coap:resend
    DIAG_ID_CLOUD_UNACKNOWLEDGED_MESSAGES = 22, // coap:unack
    DIAG_ID_CLOUD_RATE_LIMITED_EVENTS = 20, // pub:throttle
    DIAG_ID_SYSTEM_TOTAL_RAM = 25, // sys:tram
    DIAG_ID_SYSTEM_USED_RAM = 26, // sys:uram
    DIAG_ID_USER = 32768 // Base value for application-specific source IDs
} diag_id;
Diagnostic Helper Functions
There are only two functions in the DiagnosticHelperRK library:
getValue
Gets a single diagnostic value.
int32_t DiagnosticHelper::getValue(uint16_t id);
The id is the code above, such as DIAG_ID_CLOUD_CONNECTION_ERROR_CODE.
You might use it like this:
Log.info("cloud:err=%d", DiagnosticsHelper::getValue(DIAG_ID_CLOUD_CONNECTION_ERROR_CODE));
getJson
Gets the diagnostic data as a JSON object in a String.
String DiagnosticHelper::getJson();
For example, you might get something like this on a Photon:
{"sys:uptime":2001,"net:stat":4,"net:err":0,"cloud:stat":2,"net:dconn":0,"cloud:err":0,"cloud:dconn":0,"net:rssi":-18688,"pub:limit":0,"coap:unack":0,"sys:tram":83200,"sys:uram":32992,"net:connatt":1,"net:dconnrsn":0,"cloud:connatt":1,"cloud:dconnrsn":0,"net:sigstr":13823,"net:sigqual":8257,"net:sigqualv":1245184,"net:at":1,"net:sigstrv":-4784128,"_":""}
Examples
1-get-values
#include "Particle.h"
#include "DiagnosticsHelperRK.h"
SerialLogHandler logHandler;
const unsigned long CHECK_INTERVAL_MS = 5000;
unsigned long lastCheck = 0;
	Serial.begin();
	if (millis() - lastCheck >= CHECK_INTERVAL_MS) {
		lastCheck = millis();
		// Constants for the various diagnostics items can be found here:
		// https://github.com/particle-iot/firmware/blob/develop/services/inc/diagnostics.h
		Log.info("cloud:stat=%d", DiagnosticsHelper::getValue(DIAG_ID_CLOUD_CONNECTION_STATUS));
		Log.info("cloud:dconn=%d", DiagnosticsHelper::getValue(DIAG_ID_CLOUD_DISCONNECTS));
		Log.info("cloud:connatt=%d", DiagnosticsHelper::getValue(DIAG_ID_CLOUD_CONNECTION_ATTEMPTS));
		Log.info("cloud:dconnrsn=%d", DiagnosticsHelper::getValue(DIAG_ID_CLOUD_DISCONNECTION_REASON));
Running this, you’d see something like this on the debug serial:
0000010000 [app] INFO: cloud:stat=2
0000010000 [app] INFO: cloud:err=0
0000010000 [app] INFO: cloud:dconn=0
0000010000 [app] INFO: cloud:connatt=1
0000010000 [app] INFO: cloud:dconnrsn=0
2-get-json
This example gets the JSON data and publishes it when the “pub” function is called.
int pubHandler(String data);
	Serial.begin();
	Particle.function("pub", pubHandler);
int pubHandler(String data) {
	String json = DiagnosticsHelper::getJson();
	Particle.publish("diagData", json, PRIVATE);
	return 0;
You might see something like this in the event log:
Thanks for this @rickkas7! You are the best.
Thanks for helping make these features much easier to understand and use!
Shouldn't this be pub:limit ?
You are correct, however the comment in the diagnostics.h file in the source is actually wrong, that’s where that came from. It indeed should be:
DIAG_ID_CLOUD_RATE_LIMITED_EVENTS = 20, // pub:limit
Rick - You are on a roll… Keep rockin’ these posts! My forum bookmark collection continues to grow with these excellent informational nuggets!
Awesome Rick,
I was just wondering how I was going to do this and a quick search brought me here. Thanks for keeping one step ahead.
Cheers
@rickkas7 Device Vitals Metadata is a bit lite on the meaning of the values. Is there a fuller explanation of each vital, its values and their meanings?
The device vitals metadata is all that’s available right now.
