Here are the basics of getting started with Photon development using Ubuntu 15.10 “Wily Werewolf” Linux. You will need nodejs, npm, particle-cli, and dfu-util on your machine.
Clear out any OLD stuff:
sudo apt-get remove nodejs npm
sudo apt-get purge nodejs npm
sudo apt-get autoremove
Get current nodejs and npm: (To save frustration, note that Node.js v0.12 and v5.x DON’T work in Ubuntu 15.10)
curl -sL https://deb.nodesource.com/setup_4.x | sudo -E bash -
sudo apt-get install -y nodejs
Now setup particle-cli by using npm:
sudo npm install -g particle-cli
Now use the Ubuntu Software Center app (or apt-get) to install dfu-util, currently v0.8-1. Now start developing!
Hope this saved you some time!
-Ron B.
Is there an IDE to use with these tools ?
Is there a link to explain what this means.
Yes, once you have the basics installed, then you would use the Particle build system that is browser based. You would need to setup an account at https://build.particle.io/login. There is a Linux based development system that can be installed locally, but not available yet; you should keep checking with Particle to see when that is available!
When you install Ubuntu on your machine, the default program for adding/deleting programs is called “Ubuntu Software Center.” If for some reason that is not installed on your machine then get used to the command line (terminal) and try this:
sudo apt-get install dfu-util
Hope that helps!
Are any of the things you mentioned an IDE ??
I do have ubuntu installed on my laptop.
I do have an account on build.particle.io and I have used it a few times.
Now,
I want to compile programs for Particle in Ubuntu and down load the code to the Particle using USB.
Can this be done in a simple say ?
Is there a web page that describes the steps to do this ?
Here is a great tutorial for Photon development: https://learn.sparkfun.com/tutorials/photon-development-guide/all
There are lots of documents from Particle also.
Have fun!
