ScruffR
6
There are several threads in this forum that could get you started
Search results for 'arduino photon' - Particle
Most of them get stuck at some point, that's why the posted here, but the solutions should be there too.
But if this doesn't get you anywhere, we're here to help
This seems to be a good one, although the level shifting should not be required for the Photon as the RX/TX pins are 5V tolerant.
There are also some things that have slightly changed since 2014, but the general idea is in the code.
