I’m starting to play around with the Workbench and tried compiling my project. It gave me around 250 errors. One of which is listed below. I’m using many if platform == in my project.
The same code compiled fine when I do it over the cloud outside of VS.
Does anyone know why the below is giving an error?
Are you sure that PLATFORM_ELECTRON_PRODUCTION and PLATFORM_P1 are defined and that PLATFORM_ID is set to one or the other? You could insert another #elif before #endif and insert the PLATFORM_ID into a Serial.print().
