I keep getting this error with dev which seems to do with the binary file. It does not let me delete it. when I copy my files to another folder and compile and flash it works fine though. How do i get rid of the binary file! windows tells me that i need admin rights to delete it, but i am logged in as admin!
[Enter steps to reproduce below:]
Atom Version: 1.5.1
System: Microsoft Windows 7 Professional
Thrown From: spark-dev package, v0.0.32
Stack Trace
Uncaught Error: EPERM: operation not permitted, stat ‘C:\Users\farhad\Google Drive\farhad\git\test\test_repo\BlinkM_LED\photon_firmware_1460651876420.bin’
At fs.js:854
Error: EPERM: operation not permitted, stat 'C:\Users\farhad\Google Drive\farhad\git\test\test_repo\BlinkM_LED\photon_firmware_1460651876420.bin'
at Error (native)
at fs.statSync (fs.js:854:18)
at Object.fs.statSync (ATOM_SHELL_ASAR.js:225:16)
at Function.<anonymous> (C:\Users\farhad\AppData\Local\particle\app-1.5.1\resources\app.asar\node_modules\spark-dev\lib\views\select-firmware-view.js:40:20)
at Function.View.buildHtml (C:\Users\farhad\AppData\Local\particle\app-1.5.1\resources\app.asar\node_modules\atom-space-pen-views\node_modules\space-pen\lib\space-pen.js:123:10)
at Function.View.render (C:\Users\farhad\AppData\Local\particle\app-1.5.1\resources\app.asar\node_modules\atom-space-pen-views\node_modules\space-pen\lib\space-pen.js:129:19)
at exports.$$ (C:\Users\farhad\AppData\Local\particle\app-1.5.1\resources\app.asar\node_modules\atom-space-pen-views\node_modules\space-pen\lib\space-pen.js:627:24)
at SelectFirmwareView.module.exports.SelectFirmwareView.viewForItem (C:\Users\farhad\AppData\Local\particle\app-1.5.1\resources\app.asar\node_modules\spark-dev\lib\views\select-firmware-view.js:38:14)
at SelectFirmwareView.module.exports.SelectListView.populateList (C:\Users\farhad\AppData\Local\particle\app-1.5.1\resources\app.asar\node_modules\atom-space-pen-views\lib\select-list-view.js:206:29)
at SelectFirmwareView.module.exports.SelectListView.setItems (C:\Users\farhad\AppData\Local\particle\app-1.5.1\resources\app.asar\node_modules\atom-space-pen-views\lib\select-list-view.js:167:12)
at C:\Users\farhad\AppData\Local\particle\app-1.5.1\resources\app.asar\node_modules\spark-dev\lib\spark-dev.js:905:40
at Object.module.exports.projectRequired (C:\Users\farhad\AppData\Local\particle\app-1.5.1\resources\app.asar\node_modules\spark-dev\lib\spark-dev.js:382:14)
at C:\Users\farhad\AppData\Local\particle\app-1.5.1\resources\app.asar\node_modules\spark-dev\lib\spark-dev.js:828:24
at C:\Users\farhad\AppData\Local\particle\app-1.5.1\resources\app.asar\node_modules\spark-dev\lib\spark-dev.js:373:18
at Object.module.exports.loginRequired (C:\Users\farhad\AppData\Local\particle\app-1.5.1\resources\app.asar\node_modules\spark-dev\lib\spark-dev.js:364:14)
at Object.module.exports.deviceRequired (C:\Users\farhad\AppData\Local\particle\app-1.5.1\resources\app.asar\node_modules\spark-dev\lib\spark-dev.js:367:19)
at Object.module.exports.flashCloud (C:\Users\farhad\AppData\Local\particle\app-1.5.1\resources\app.asar\node_modules\spark-dev\lib\spark-dev.js:826:19)
at atom-workspace.disposables.add.atom.commands.add.spark-dev:flash-cloud (C:\Users\farhad\AppData\Local\particle\app-1.5.1\resources\app.asar\node_modules\spark-dev\lib\spark-dev.js:137:26)
at CommandRegistry.module.exports.CommandRegistry.handleCommandEvent (C:\Users\farhad\AppData\Local\particle\app-1.5.1\resources\app.asar\src\command-registry.js:260:29)
at CommandRegistry.handleCommandEvent (C:\Users\farhad\AppData\Local\particle\app-1.5.1\resources\app.asar\src\command-registry.js:3:61)
at CommandRegistry.module.exports.CommandRegistry.dispatch (C:\Users\farhad\AppData\Local\particle\app-1.5.1\resources\app.asar\src\command-registry.js:160:19)
at space-pen-button.<anonymous> (C:\Users\farhad\AppData\Local\particle\app-1.5.1\resources\app.asar\node_modules\tool-bar\lib\tool-bar-button-view.js:42:36)
at space-pen-button.jQuery.event.dispatch (C:\Users\farhad\AppData\Local\particle\app-1.5.1\resources\app.asar\node_modules\jquery\dist\jquery.js:4435:9)
at space-pen-button.elemData.handle (C:\Users\farhad\AppData\Local\particle\app-1.5.1\resources\app.asar\node_modules\jquery\dist\jquery.js:4121:28)
Commands
-9:59.2.0 tree-view:remove-project-folder (span.name.icon.icon-repo)
-9:46.4.0 spark-dev:core-status-updated (atom-workspace.workspace.scrollbars-visible-always.theme-monokai.theme-one-dark-ui)
-9:39.9.0 spark-dev:flash-cloud (atom-text-editor.editor)
12x -9:16.6.0 spark-dev:core-status-updated (atom-workspace.workspace.scrollbars-visible-always.theme-monokai.theme-one-dark-ui)
-3:45.1.0 spark-dev:flash-cloud (atom-text-editor.editor)
7x -3:16.6.0 spark-dev:core-status-updated (atom-workspace.workspace.scrollbars-visible-always.theme-monokai.theme-one-dark-ui)
-0:15.3.0 spark-dev:flash-cloud (atom-text-editor.editor)
Config
"core": {
"themes": [
"one-dark-ui",
"monokai"
"spark-dev": {}
Installed Packages
# User
No installed packages
# Dev
No dev packages
