Getting error no matching function for call to 'NtpTime::NtpTime(const char*&, int, int)'
I don’t remember what did I change recently, but now I have started getting an error:
relay_led_light.ino:17:49: no matching function for call to 'NtpTime::NtpTime(const char*&, int, int)'
I have included the ntpTime library following the usual step.
#include <NtpTime.h>
#define RELAY1  1
int inputPin = D0;              // choose the input pin (for PIR sensor)
int pirState = LOW;             // we start, assuming no motion detected
int val = 0;                    // variable for reading the pin status
NtpTime* ntpTime;
unsigned long fadeStartTime = 0;
unsigned long fadeDuration = 60000; // 60 seconds
    pinMode(RELAY1, OUTPUT);
    pinMode(inputPin, INPUT);     // declare sensor as input
    const char* ntpServer = "pool.ntp.org";
    ntpTime = new NtpTime(ntpServer, 3600, 60000);
    // ntpTime = new NtpTime("pool.ntp.org", 3600, 60000);
    ntpTime->begin();
void readTheSensor() {
    val = digitalRead(inputPin);
    ntpTime->update();
    readTheSensor();
    if (val == HIGH) {
        // motion detected
        if (pirState == LOW) {
            // motion is just detected
            pirState = HIGH;
            setLEDStrip(pirState);
            fadeStartTime = millis();
    else {
        // no motion detected
        if (pirState == HIGH) {
            // motion is just ended
            if (millis() - fadeStartTime > fadeDuration) {
                pirState = LOW;
            } else {
                int brightness = map(millis() - fadeStartTime, 0, fadeDuration, 255, 0);
                analogWrite(RELAY1, brightness);
void setLEDStrip(int state) {
    if (state == LOW) {
        digitalWrite(RELAY1, LOW);
    else {
        analogWrite(RELAY1, 255);
That’s because there are only these three constructors
none of which fits your call.
However, what is the reason for using that library?
What does the built-in Time object not provide?
Also what is the rationale for instantiating the NtpTime object in setup() and not on initialization? You instantiate it only once anyhow.
