Get spark status (connected or not)
Hello,
I lost the link that shows the status of spark, only if it is connected or not. Can anyone give me this link? I searched the forum and did not find him. I just want to know if the spark is on.
Thank you very much help.
Do you mean https://dashboard.particle.io/user/devices
thank you for answer, but don’t is it.
is a link https://api.particle.io/v1/devices/corenumber/!!!/?access_token=tokennumber
so You receive the status, if is connected or no
I found the solution
http://192.168.1.6:8080/v1/devices/deviceid/?access_token=token
Taking a look at the documentation might help as well :wink:
http://docs.particle.io/core/api/#introduction-device-information
thank you Moors7.
