I also entered some query parameters, so my question is whether this data will be parsed automatically based on the query parameters entered? If so, Is this done in the code section below?
damn... this coding thing is hard I will make the change.
I am able to serial print the data from the end point data, it looks like this:
Data: hook-response/get_data/0
{"id":1,"readerId":21312,"readerMode":"ScanIn","roomName":"Grand Ballroom","events":[{"title":"Who Do You Think You Are?: Best Practices in Human Resources","startTime":"2025-10-14T12:55:00+00:00","endTime":"2025-10-14T13:45:00+00:00","instructorFirstName":"Toby","instructorLastName":"Flenderson"},{"title":"Keynote: Using Mnemonic Devices to Enhance Your Paper-Selling Skillset","startTime":"2025-10-14T14:00:00+00:00","endTime":"2025-10-14T16:00:00+00:00","instructorFirstName":"Michael","instructorLastName":Data: hook-response/get_data/1
"Scott"}]}
From here I need to put each of those parameters in a variable so I can display them on a epaper display.
In case you won't need all the data from that response, you can already filter out the valuable data in the Webhook definition.
As it seems your response may also exceed the maximum chunk size for a single event and hence you'll need to first stitch all the response chunks together before being able to successfully parse it.
