Gen 4 (Realtek RTL8722DM) Internal Temperature?
On the Borons, we can access the processor temperature with the following code:
	// Get die temperature in 0.25 degrees Celsius.  Takes 50 us to complete.
	int32_t temp;
	uint32_t res = sd_temp_get(&temp);
	if (res == NRF_SUCCESS) {
		chip_temp = (float)temp / 4;
		Serial.printf("\nchip_temp=%.1f\n", chip_temp);
Do we have something similar with the Gen 4 devices, like the M-Series and P2?
I’ve searched the Realtek RTL8722DM datasheet but haven’t had any luck.
There is no internal temperature sensor on RTL872x MCUs.
Thanks, Rick!
