GCC Versions and SRAM sizes, later versions doesn't compile
So I've been slowly downgrading the ARM GCC version to build the System Firmware.
I started on the latest, Then moved to 5.9.x and now moved to 4.9.x, it seems that anything more that 4,9.x either does not compile with errors like
ld.exe: region SRAM overflowed by 16 bytes
or things like
particle::CompletionHandlerList has not been declared.
I would have thought that a later version of the GCC would improve size and speed?
Anyone had this issue and resolved it?
Jfp
Hello,
Let me ping someone that might be able to help, @tylercpeacock are you able to assist?
Kyle
@johnnyfp, @BDub said in another topic:
:slight_smile:
Thanks, not sure why the search didn’t bring that topic up. English language can be so convoluted with different words for the same meaning.
Thanks for the help!
