System build (electron) failing
Hi
I’m trying to build the system (OS etc) and when I do the make from the /firmware/modules directory, I get an error on system-part2 that it won’t fit into the SRAM
make clean all PLATFORM=electron
Building target: …/…/…/build/target/system-part2/platform-10-m/system-part2.elf
Invoking: ARM GCC C++ Linker
mkdir -p …/…/…/build/target/system-part2/platform-10-m/
arm-none-eabi-g++ -DSTM32_DEVICE -DSTM32F2XX -DPLATFORM_THREADING=1 -DPLATFORM_ID=10 -DPLATFORM_NAME=electron -DUSBD_VID_SPARK=0x2B04 -DUSBD_PID_DFU=0xD00A -DUSBD_PID_CDC=0xC00A -g3 -gdwarf-2 -Os -mcpu=cortex-m3 -mthumb -DPRODUCT_ID=10 -DPRODUCT_FIRMWARE_VERSION=65535 -DUSE_STDPERIPH_DRIVER -DDFU_BUILD_ENABLE -fno-builtin -DSYSTEM_VERSION_STRING=0.6.2 -DRELEASE_BUILD -Werror -I…/…/…/modules/electron/system-part2/inc -I…/…/…/modules/shared/stm32f2xx/inc -I…/…/…/communication/src -I…/…/…/services/inc -I…/…/…/platform/shared/inc -I…/…/…/platform/MCU/STM32F2xx/STM32_USB_Host_Driver/inc -I…/…/…/platform/MCU/STM32F2xx/STM32_StdPeriph_Driver/inc -I…/…/…/platform/MCU/STM32F2xx/STM32_USB_OTG_Driver/inc -I…/…/…/platform/MCU/STM32F2xx/STM32_USB_Device_Driver/inc -I…/…/…/platform/MCU/STM32F2xx/SPARK_Firmware_Driver/inc -I…/…/…/platform/MCU/shared/STM32/inc -I…/…/…/platform/MCU/STM32F2xx/CMSIS/Include -I…/…/…/platform/MCU/STM32F2xx/CMSIS/Device/ST/Include -I…/…/…/dynalib/inc -I…/…/…/rt-dynalib/inc -I…/…/…/modules/shared/stm32f2xx/inc -I. -MD -MP -MF …/…/…/build/target/system-part2/platform-10-m/system-part2.elf.d -ffunction-sections -fdata-sections -Wall -Wno-switch -Wno-error=deprecated-declarations -fmessage-length=0 -fno-strict-aliasing -DSPARK=1 -DPARTICLE=1 -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSTART_YMODEM_FLASHER_SERIAL_SPEED=28800 -fno-builtin-malloc -fno-builtin-free -fno-builtin-realloc -DUSER_FIRMWARE_IMAGE_SIZE=0x20000 -DUSER_FIRMWARE_IMAGE_LOCATION=0x8080000 -DMODULAR_FIRMWARE=1 -DMODULE_VERSION=108 -DMODULE_FUNCTION=4 -DMODULE_INDEX=1 -DMODULE_DEPENDENCY=4,3,108 -D_WINSOCK_H -D_GNU_SOURCE …/…/…/build/target/system-part2/platform-10-m/…/…/…/modules/electron/system-part2/src/module_system_part1.o …/…/…/build/target/system-part2/platform-10-m/…/…/…/modules/electron/system-part2/src/init_dynalib.o …/…/…/build/target/system-part2/platform-10-m/…/…/…/modules/electron/system-part2/src/module_info.o …/…/…/build/target/system-part2/platform-10-m/…/…/…/modules/electron/system-part2/src/import_rt.o …/…/…/build/target/system-part2/platform-10-m/…/…/…/modules/electron/system-part2/src/newlib.o --output …/…/…/build/target/system-part2/platform-10-m/system-part2.elf -nostartfiles -Xlinker --gc-sections -L…/…/…/build/arm/linker/stm32f2xx -L…/…/…/build/arm/linker/stm32f2xx -L…/…/…/build/target/communication/platform-10-m-prod-10/ -L…/…/…/build/target/hal-dynalib/platform-10-m/ -L…/…/…/build/target/services/platform-10-m/ -L…/…/…/build/target/platform/platform-10-m/ -L…/…/…/build/arm/linker -Wl,–whole-archive -lcommunication -lhal-dynalib -lservices -lplatform -Wl,–no-whole-archive --specs=nano.specs -lnosys -T…/…/…/modules/electron/system-part2/linker.ld -L…/…/…/modules/electron/system-part3 -L…/…/…/modules/electron/system-part1 -Wl,–defsym,PLATFORM_DFU=0x8020000 -Wl,-Map,…/…/…/build/target/system-part2/platform-10-m/system-part2.map
/home/tinyspud/Desktop/gcc-arm-none-eabi-5_4-2016q3/bin/…/lib/gcc/arm-none-eabi/5.4.1/…/…/…/…/arm-none-eabi/bin/ld: …/…/…/build/target/system-part2/platform-10-m/system-part2.elf section .bss' will not fit in regionSRAM’
/home/tinyspud/Desktop/gcc-arm-none-eabi-5_4-2016q3/bin/…/lib/gcc/arm-none-eabi/5.4.1/…/…/…/…/arm-none-eabi/bin/ld: static RAM use exceeds allocated space
/home/tinyspud/Desktop/gcc-arm-none-eabi-5_4-2016q3/bin/…/lib/gcc/arm-none-eabi/5.4.1/…/…/…/…/arm-none-eabi/bin/ld: region `SRAM’ overflowed by 20 bytes
…/…/…/build/module.mk:222: recipe for target ‘…/…/…/build/target/system-part2/platform-10-m/system-part2.elf’ failed
I’m going from the branch release/stable
Check your compiler version:
Thanks - is there a recommended version? I’m using 5.4
https://docs.particle.io/faq/particle-tools/local-build/electron/
Currently, the 4.9-2015-q3-update is recommended. The 5.3.1 version can be used now and will be used for cloud compiles starting with system firmware 0.7.0. The 5.4.x and 6.x versions are not recommended at this time.
Thanks - guess I missed that
