I am working with particle electron 3G to send files to FTP server. I have read the AT command datasheet for onboard ublox gsm modem and found that first you have to create file at file system of gsm modem and then transfer it from there using “AT+UFTPC=5,” command. I am having trouble writing data from sdcard file to gsm modem file system. I have written this code to write data from sdcard file to gsm modem file system. Also, i have tried similar approach with Arduino MKR 1400 board which also has onboard gsm modem from ublox and i am able to upload file to FTP server. Can anyone help me resolve this issue?
Thank you.
#include <SdFat.h>
#include "cellular_hal.h"
#include "Particle.h"
// Pick an SPI configuration.
// See SPI configuration section below (comments are for photon).
#define SPI_CONFIGURATION 0
// Setup SPI configuration.
#if SPI_CONFIGURATION == 0
// Primary SPI with DMA
// SCK => A3, MISO => A4, MOSI => A5, SS => A2 (default)
SdFat sd;
const uint8_t chipSelect = SS;
#elif SPI_CONFIGURATION == 1
// Secondary SPI with DMA
// SCK => D4, MISO => D3, MOSI => D2, SS => D1
SdFat sd(1);
const uint8_t chipSelect = D1;
#elif SPI_CONFIGURATION == 2
// Primary SPI with Arduino SPI library style byte I/O.
SdFatLibSpi sd;
#elif SPI_CONFIGURATION == 3
// Software SPI. Use any digital pins.
// MISO => D5, MOSI => D6, SCK => D7, SS => D0
SdFatSoftSpi<D5, D6, D7> sd;
const uint8_t chipSelect = D0;
#endif // SPI_CONFIGURATION
File myFile;
#define MAX_PHONE_NUMBER 14
#define TIMEOUT 10000
String apn = "airtelgprs.com";
String username = "";
String password = "";
STARTUP(cellular_credentials_set(apn, username, password, NULL));
char PhoneNumber[MAX_PHONE_NUMBER] = "";
char szReturn[32] = "";
char data[512];
int file_size_sd;
// Wait for USB Serial
while (!Serial)
SysCall::yield();
Serial.println("Starting cellular, waiting 10s.");
Cellular.on();
delay(5000);
Serial.println("Cellular started. Ready to receive AT commands.");
Serial.println();
if (!sd.begin(chipSelect, SPI_HALF_SPEED))
sd.initErrorHalt();
// open the file for write at end like the "Native SD library"
if (!myFile.open("data.txt", O_RDWR))
sd.errorHalt("opening data.txt for write failed");
if (myFile)
file_size_sd = myFile.size();
Serial.println(file_size_sd);
delay(2000);
Cellular.command(callback, szReturn, 1000, "AT+ULSTFILE=\r\n"); //list file on gsm file system
Cellular.command(callback, szReturn, 1000, "AT+ULSTFILE=1\r\n"); //Get free space in the file system (in bytes)
Cellular.command(callback, szReturn, 1000, "AT+UDWNFILE=\"data.txt\",500000\r\n"); //create file o gsm file system (500kb)
Serial.println("Copy file data");
while (myFile.available() > 0)
Cellular.command(callback, szReturn,200, (const char*)myFile.read());
Serial.println("Done Writing");
Serial.println("Close file!");
myFile.close();
int callback(int type, const char* buf, int len, char* param)
Serial.print("Return: ");
Serial.write((const uint8_t*)buf, len);
Serial.println();
return WAIT;
I will try experimenting with your code.
