Flashing Raspberry Pi loses Connection
Hey there,
Attempting to Flash Raspberry Pi with Web IDE and it loses connection as soon as i try to.
(Device stops “breathing” and is disconnected)
sudo particle-agent status gives me this :
Active: active (running) since Tue 2017-05-16 01:44:42 UTC; 10min ago
executing sudo particle-agent restart makes it come back but attempting another Flash does the same.
Any idea on this ?
Thank you,
Hello,
Let me ping someone that might be able to help you. @rickkas7 are you able to assist?
Kyle
Any news on this ?
Well, after looking at the logs, it seems the connection is intermittent.
Here is what a slice of the logs looks like :
I get this error over and over again after flashing my pi a first time (i think).
Any one can help ?
0000000004 system: INFO: Cloud: connecting
terminate called after throwing an instance of 'boost::exception_detail::clone_impl<boost::exception_detail::error_info_injectorboost::system::system_error >'
what(): resolve: Host not found (non-authoritative), try again later
Firmware exited with status pid 2993 SIGABRT (signal 6)
Quitting firmware gracefully
Thank you,
