Flashing mqtt-tls library in Argon
I did not have to do that. Any reason on your end?
what if you revert that change?
no i mean i reported all the lines that are active on the mbedtels_config.h files because it may be that there is some relation that doesn’t allow me to connect on port 8883. Are you able to connect? Is there something related to toolchains etc maybe?
I am able to connect, no toolchains issues.
What if you start fresh opening a new project?
by starting a new project it works! Thank you
