Firmware v0.2.0 released, with many fixes
I’ll write up the new spec a bit later, but there will be three potential states of the Core running, each with different lights:
Breathing white: Your code is running, but the Wi-Fi module is off
Breathing green: Your code is running and the Wi-Fi module is on, but you’re not connected to the Cloud
Breathing cyan: Your code is running and you’re connected to the Cloud
