FastLED WS2801 Verification errors and Runtime problems
Hi there,
I have recently purchased a 50pc WS2801 Pixel LED string for a Particle Photon project, but seem to be tripping up at the first hurdle.
Using the FastLED (3.1.5) library I am running the provided GitHub example ‘FirstLight.ino’ (https://github.com/focalintent/FastLED-Sparkcore/blob/master/firmware/examples/FirstLight/FirstLight.ino).
I have added data and clock as follows:
// Data pin that led data will be written out over
#define DATA_PIN A5
// Clock pin only needed for SPI based chipsets when not using hardware SPI
#define CLOCK_PIN A3
And have uncommented the line:
FastLED.addLeds<WS2801, DATA_PIN, CLOCK_PIN, RGB>(leds, NUM_LEDS);
However this triggered the same issues as [this user] (https://github.com/FastLED/FastLED/issues/166#issuecomment-152818523), I managed to compile this code by following the advice of ‘Jasoncoon’ in the following message. Editing the line to read:
FastLED.addLeds<WS2801, DATA_PIN, CLOCK_PIN>(leds, NUM_LEDS);
Despite this, my LED string still does not function as coded. It is wired as follows:
  • +5v and GND - connected to a separate 5V 2A plug DC socket
  • 3pin JST SM connector from LEDs - connected to the particle photon with Data wire: A5, Clock: A3, GND: Photon GND
Is there a problem with the code, or have a wired something faulty? Thank you in advance!
you might try the digital pins e.g:
#define DATA_PIN D5
#define CLOCK_PIN D6
Hi thanks for the tip, however the real reason was I required the circuit to be globally grounded, i.e. data pins and power all needed to route through the particle’s ground pin.
