Dear all,
Currently I am using Workbench Platform.
Suppose in my application code I want to do :
#ifdef EXPERIMENTAL
// Experimental code here
#endif
And I want to define this macro from outside of my code, does the platform provide any convenient method to do this?
Ok I found the solution already, we can use additional make param EXTRA_CFLAGS so if you are using Workbench Platform you can use:
make -f $MAKE_FILE clean-user
make -f $MAKE_FILE compile-all EXTRA_CFLAGS="-DAPP_EXPERIMENTAL"
$MAKE_FILE is environement variable set to point to the Makefile to build binary which is typically:
export MAKE_FILE=$HOME/.particle/toolchains/buildscripts/1.9.2/Makefile
Hopefully it is useful for others
