Hi, currently I am looking into the source code of spark-protocol. and in DeviceServer.js there is core connected and disconnected event. and now I want to expose these two events outside DeviceServer.js, so I can use DeviceServer in this way.
var DeviceServer = require("spark-protocol").DeviceServer;
var server = new DeviceServer({
coreKeysDir: settings.coreKeysDir
global.server = server;
server.start();
server.on('ready', function () {
console.log('an ready event has happened');
server.on('disconnect', function () {
console.log('an disconnect event has happened');
Therefore I modified the code in this way by using the eventemiter.
var DeviceServer = function (options) {
//////////////// my change //////////////
var EventEmitter = require('events').EventEmitter;
util.inherits(this, EventEmitter);
this.options = options;
this.options = options || {};
settings.coreKeysDir = this.options.coreKeysDir = this.options.coreKeysDir || settings.coreKeysDir;
this._allCoresByID = {};
this._attribsByID = {};
this._allIDs = {};
this.init();
and inside the start function, I made the change like this
core.on('ready', function () {
logger.log("Core online!");
var coreid = this.getHexCoreID();
that._allCoresByID[coreid] = core;
that._attribsByID[coreid] = that._attribsByID[coreid] || {
coreID: coreid,
ip: this.getRemoteIPAddress(),
product_id: this.spark_product_id,
firmware_version: this.product_firmware_version
///// my change
that.emit('ready');
core.on('disconnect', function (msg) {
logger.log("Session ended for " + core._connection_key);
delete _cores[key];
/////////////////////// my change
that.emit('disconnect');
However, it doesn’t work with errors
I’ve edited your post to properly format the code. Please check out this post, so you know how to do this yourself in the future. Thanks in advance! ~Jordy
