Hello
in a remote control sketch I use functions. Up to version 2.1.0 I never received an error message, I wanted to update my Boron with version 2.2.0 but I get the following error for both functions:
remotecontrolmognev1.ino: 122: 5: control reaches end of non-void function [-Werror = return-type].
I am attaching the complete sketch so that we can verify the code.
Valentino
// ***** Controllo remoto x Mognenigo con STATO si riceve un "1" o "0" visibile in VB sul Browser *****
#define ON 1
#define OFF 0
int BstartState = 0;
int BStato=0;
int RstartState = 0;
int RStato=0; //
//int trunkState = 0;
//int lockState = 0;
// BOILER
int BSTARTPIN = D0;
int BREADPIN=D1;
// RISC
int RSTARTPIN = D2;
int RREADPIN=D3;
//int LOCKPIN = D5;
//int UNLOCKPIN = D4;
//***Variabili misura temperatura Sonda Wall Wangzi shell
int pinTemp=A0;
int sensorT=0;
double voltT=0;
double Temp=0;
//***Variabili misura Umidita Sonda Wall Wangzi shell
int pinUmi=A1;
int sensorU=0;
double voltU=0;
double Umi=0;
uint32_t UPDATE_INTERVAL = 1000; // in milliseconds
uint32_t FIFTEEN_MINUTES = 60*15*1000; // in milliseconds
// BOILER
uint32_t lastTime = 0; // in milliseconds
uint32_t startTime = 0; // in milliseconds
// RISC
uint32_t RlastTime = 0; // in milliseconds
uint32_t RstartTime = 0; // in milliseconds
Particle.keepAlive(120);// serve per mantenere il collegamento con il provider telefonia
Particle.function("Bstart", BstartFunction);
Particle.variable("Bstartstate", &BstartState, INT);
Particle.variable("BStato",BStato);
Particle.function("Rstart", RstartFunction);
Particle.variable("Rstartstate", &RstartState, INT);
Particle.variable("RStato",RStato);
pinMode(BSTARTPIN,OUTPUT);
pinMode(BREADPIN,INPUT_PULLDOWN);
digitalWrite(BSTARTPIN,LOW);
digitalWrite(RSTARTPIN,LOW);
pinMode(RSTARTPIN,OUTPUT);
pinMode(RREADPIN,INPUT_PULLDOWN);
//***Calcolo Dati Temperatura Sonda Wall Wangzi shell
sensorT = analogRead(pinTemp);
voltT = (3.3 * sensorT) / 4095.0;
Temp=-40 + (120/0.016)*(voltT/160 - 0.0038);// Per le spiegazioni calcolo vedi inizio skecht//Impostazione origine 0.004//impost.23.10.2020 ->0.0042
//Serial.print(sensorT);Serial.print(" ");Serial.print(voltT);Serial.print(" ");Serial.println(Temp);
//***Calcolo Dati Umidita Sonda Wall Wangzi shell
sensorU = analogRead(pinUmi);
voltU = (3.3 * sensorU) / 4095.0;
Umi=(100/0.016)*(voltU/160 - 0.0042); // Impostazione origine 0.004
Serial.print(sensorU);Serial.print(" ");Serial.print(voltU);Serial.print(" ");Serial.println(Umi);
//Publish Tem&Umidita Sonda Wall Wangzi shell
char tdata[32];
//snprintf(tdata, sizeof(tdata), "temp:%.1f,umi:%.1f", Temp, Umi);
snprintf(tdata, sizeof(tdata), "temp:%.2f,umi:%.2f", Temp, Umi);
Particle.publish("dhtData",tdata, PRIVATE);
//Particle.publish("dhtData",tdata, PUBLIC);
Serial.print("Temp:");Serial.print(Temp);Serial.print(" ");Serial.print("Umi:");Serial.println(Umi);
delay(1000);
BStato=digitalRead(BREADPIN);
Serial.print("Boiler: ");Serial.println(BStato);
RStato=digitalRead(RREADPIN);
Serial.print("RISC: ");Serial.println(RStato);
delay(5000);
//**** BOILER **** //
int BstartFunction(String args)
if(BstartState == OFF)
BstartState = ON; // engine started
//startTime = millis(); // Modifica 02062019
digitalWrite(BSTARTPIN, HIGH); // Double press the start button to start
//Stato=digitalRead(READPIN); // Modifica 02062019
return 200; // This is checked in the web app controller for validation
else if (BstartState == ON)
BstartState = OFF; // engine stopped
//digitalWrite(STARTPIN, HIGH); // Modifica 02062019 // Single press the start button to stop
//delay(500);// Modifica 02062019
digitalWrite(BSTARTPIN, LOW); // Modifica 02062019
//**** RISC **** // Update the filter every 10ms (default)
int RstartFunction(String args)
if(RstartState == OFF) {
RstartState = ON; // engine started
digitalWrite(RSTARTPIN, HIGH); // Double press the start button to start
else if (RstartState == ON)
RstartState = OFF; // engine stopped
digitalWrite(RSTARTPIN, LOW); // Modifica 02062019
