I’m getting the compile error “build didn’t produce binary Error: stderr maxBuffer exceeded”. Google didn’t show any results of other people with a photon having this error. I’m using the local IDE for Windows and a Particle Photon.
I’m pretty sure I know exactly what is causing this error, I’m trying to compile code with a massive 128x128x16 full colour bitmap written as an unsigned char in the code itself (because I don’t have an SD card reader). Here’s just the first two lines of what I’m pretty sure is breaking the compiler:
const unsigned char image1[] = {
0x8472, 0x8472, 0x8472, 0x8472, 0x8472, 0x8472, 0x8472, 0x8472, 0x8472, 0x8472, 0x8472, 0x8472, 0x8472, 0x8472, 0x8472, 0x8492, 0x8492, 0x8492, 0x8492, 0x8492, 0x8492, 0x8492, 0x8492, 0x8492, 0x8492, 0x8492, 0x8492, 0x8492, 0x8492, 0x8492, 0x8492, 0x8c92, 0x8c92, 0x8c92, 0x8c92, 0x8c92, 0x8c93, 0x8c93, 0x8c93, 0x8c93, 0x8c93, 0x8c92, 0x8c92, 0x8c92, 0x8c93, 0x8c93, 0x8c93, 0x8c93, 0x8c92, 0x8c92, 0x8c92, 0x8c92, 0x8c92, 0x8c92, 0x8c92, 0x8c92, 0x8c92, 0x8492, 0x8c92, 0x8492, 0x8c92, 0x8c93, 0x8c93, 0x8c93, 0x8c93, 0x8c93, 0x8c93, 0x8c93, 0x8c92, 0x8c92, 0x8c92, 0x8c92, 0x8c92, 0x8c92, 0x8c72, 0x8472, 0x8472, 0x8472, 0x8472, 0x8472, 0x8472, 0x8472, 0x8472, 0x8472, 0x8472, 0x8472, 0x8472, 0x8452, 0x8451, 0x7c51, 0x8451, 0x8451, 0x8451, 0x7c51, 0x7c51, 0x7c51, 0x7c31, 0x7c31, 0x7c31, 0x7c31, 0x7c31, 0x7c31, 0x7c31, 0x7c31, 0x7c31, 0x7431, 0x7411, 0x7411, 0x7411, 0x7411, 0x7411, 0x7410, 0x7410, 0x7bef, 0x7bce, 0x7bce, 0x7bce, 0x7bcd, 0x7bcd, 0x7bcd, 0x7bad, 0x7bad, 0x7bad, 0x73ad, 0x73ad, 0x73ad, 0x73ad, 0x73ad,
Again, that’s just the first two lines of the one 128 line section I’m pretty sure has broken it. It definitely broke the colour encoding in the local IDE, it only draws purple for about halfway through the horizontal scroll bar, and then these values turn white.
Did I do a bad thing, or did I encounter a bug?
