Error flashing anything: "Flash requires modules not present on device"
I tried flashing some c++ code, and ever since then I get the following error, even on the first simple Wiring code I tried. Don’t see this error in a search of the forum. I have a photon.
$ particle flash breadboard blinky.ino
Including:
    blinky.ino
attempting to flash firmware to your device breadboard
flash device said  {"ok":true,"message":"Flash requires modules not present on device"}
$ echo $?
0
I even tried using the web IDE to flash Tinker, and it says “Flash successful! Please wait a moment while your device is updated…” but nothing happens on my Photon. It’s still doing what it has been. I’ve disconnected the power a few times, too.
It’s stuck with what was last flashed on it.
I guess you are using a Photon?
Did you do any local work that updated the system firmware?
No, I’m brand new to dealing with hardware stuff, but I found the issue.
I wrote the following for playing with the RGB LED, and I suppose that since it takes so long for that function to return, nothing else works.
void cycle() {
  for (int r = 0; r < 256; r++) {
    for (int g = 0; g < 256; g++) {
      for (int b = 0; b < 256; b++) {
        analogWrite(REDPin,   r);
        analogWrite(GREENPin, g);
        analogWrite(BLUEPin,  b);
I was able to reset the firmware and install other code just fine, and replicate this issue.
The error message is cryptic, though.
Are you saying only a particular code is failing and the rest works on your Photon?
You are using particle-cli?
If this is running on a Photon, please put the device in Safe Mode - that will allow you to connect to the cloud and flash firmware. This is necessary since your code is blocking the main thread, stopping the system from performing any updates. n a few weeks, we will be releasing multithreading support on the Photon, which will address these kinds of problems.
I In the meantime, it’s a good idea to add a delay(1) to long loops like this call so that the system can perform background processing.
Thanks! Safe Mode is just as effective as Firmware Reset but quicker.
And yay to multithreaded support! :smiley:
I noticed a delay in the inner loop is interruptible, but even outside it with only 256 loops before a delay it still blocks:
void cycleInterruptible() {
        delay(1);
void cycleBlocks() {
      delay(1);
The reason is that the system doesn’t get a look-in until the delays accumulate to 1000 ms.
