Error during compiling for "p_10_Thermometer_Dallas" app
Hello,
I’m testing “p_10_Thermometer_Dallas” app as according to the book, named “Getting Started with the Photon”. But, I got an error during the compiling even I did as the book described.
Can you please help me to fix it?
Processing p_10_thermometer_dallas.ino
Checking library photon_book…
Checking library spark-dallas-temperature…
Checking library OneWire…
Installing library photon_book 0.0.10 to lib/photon_book …
Installing library spark-dallas-temperature 0.0.5 to lib/spark-dallas-temperature …
Installing library OneWire 2.0.1 to lib/OneWire …
Library photon_book 0.0.10 installed.
Library spark-dallas-temperature 0.0.5 installed.
Library OneWire 2.0.1 installed.
make -C …/modules/photon/user-part all
make[1]: Entering directory '/firmware/modules/photon/user-part’
make -C …/…/…/user
make[2]: Entering directory '/firmware/user’
Building cpp file: src/p_10_thermometer_dallas.cpp
Invoking: ARM GCC CPP Compiler
mkdir -p …/build/target/user/platform-6-msrc/
arm-none-eabi-gcc -DSTM32_DEVICE -DSTM32F2XX -DPLATFORM_THREADING=1 -DPLATFORM_ID=6 -DPLATFORM_NAME=photon -DUSBD_VID_SPARK=0x2B04 -DUSBD_PID_DFU=0xD006 -DUSBD_PID_CDC=0xC006 -DSPARK_PLATFORM -g3 -gdwarf-2 -Os -mcpu=cortex-m3 -mthumb -DINCLUDE_PLATFORM=1 -DPRODUCT_ID=6 -DPRODUCT_FIRMWARE_VERSION=65535 -DUSE_STDPERIPH_DRIVER -DDFU_BUILD_ENABLE -DSYSTEM_VERSION_STRING=0.7.0 -DRELEASE_BUILD -I./inc -I…/wiring/inc -I…/system/inc -I…/services/inc -I…/communication/src -I…/hal/inc -I…/hal/shared -I…/hal/src/photon -I…/hal/src/stm32f2xx -I…/hal/src/stm32 -I…/hal/src/photon/api -I…/hal/src/photon/include -I…/hal/src/photon/wiced/security/BESL/host/WICED/ -I…/hal/src/photon/wiced/security/BESL/include -I…/hal/src/photon/wiced/security/BESL -I…/hal/src/photon/wiced/security/BESL/crypto -I…/hal/src/photon/wiced/WWD/include/ -I…/hal/src/photon/wiced/platform/include/ -I…/hal/src/photon/wiced/platform/GCC/ -I…/hal/src/photon/wiced/security/BESL/supplicant/ -I…/hal/src/photon/libraries/crypto -I…/platform/shared/inc -I…/platform/MCU/STM32F2xx/STM32_USB_Host_Driver/inc -I…/platform/MCU/STM32F2xx/STM32_StdPeriph_Driver/inc -I…/platform/MCU/STM32F2xx/STM32_USB_OTG_Driver/inc -I…/platform/MCU/STM32F2xx/STM32_USB_Device_Driver/inc -I…/platform/MCU/STM32F2xx/SPARK_Firmware_Driver/inc -I…/platform/MCU/shared/STM32/inc -I…/platform/MCU/STM32F2xx/CMSIS/Include -I…/platform/MCU/STM32F2xx/CMSIS/Device/ST/Include -I…/dynalib/inc -Isrc -I./libraries -Ilib/photon_book/src -Ilib/spark-dallas-temperature/src -Ilib/OneWire/src -I. -MD -MP -MF …/build/target/user/platform-6-msrc/p_10_thermometer_dallas.o.d -ffunction-sections -fdata-sections -Wall -Wno-switch -Wno-error=deprecated-declarations -fmessage-length=0 -fno-strict-aliasing -DSPARK=1 -DPARTICLE=1 -Wundef -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSTART_YMODEM_FLASHER_SERIAL_SPEED=28800 -DBOOTLOADER_SDK_3_3_0_PARTICLE -DPARTICLE_DCT_COMPATIBILITY -DSPARK_PLATFORM_NET=BCM9WCDUSI09 -fno-builtin-malloc -fno-builtin-free -fno-builtin-realloc -DLOG_INCLUDE_SOURCE_INFO=1 -DPARTICLE_USER_MODULE -DUSER_FIRMWARE_IMAGE_SIZE=0x20000 -DUSER_FIRMWARE_IMAGE_LOCATION=0x80A0000 -DMODULAR_FIRMWARE=1 -DMODULE_VERSION=5 -DMODULE_FUNCTION=5 -DMODULE_INDEX=1 -DMODULE_DEPENDENCY=4,2,207 -DMODULE_DEPENDENCY2=0,0,0 -D_WINSOCK_H -D_GNU_SOURCE -DLOG_MODULE_CATEGORY="“app”" -fno-exceptions -fno-rtti -fcheck-new -std=gnu++11 -c -o …/build/target/user/platform-6-msrc/p_10_thermometer_dallas.o src/p_10_thermometer_dallas.cpp
In file included from p_10_thermometer_dallas.ino:5:0:
lib/spark-dallas-temperature/src/spark-dallas-temperature.h:27:36: fatal error: …/OneWire/OneWire.h: No such file or directory
#include “…/OneWire/OneWire.h”
compilation terminated.
…/build/module.mk:267: recipe for target ‘…/build/target/user/platform-6-msrc/p_10_thermometer_dallas.o’ failed
make[2]: Leaving directory '/firmware/user’
make[2]: *** […/build/target/user/platform-6-msrc/p_10_thermometer_dallas.o] Error 1
…/…/…/build/recurse.mk:11: recipe for target ‘user’ failed
make[1]: *** [user] Error 2
make[1]: Leaving directory ‘/firmware/modules/photon/user-part’
…/build/recurse.mk:11: recipe for target ‘modules/photon/user-part’ failed
make: *** [modules/photon/user-part] Error 2
Thank you,
Alex
The spark-dallas-temperature library has never been updated to support the new library format that was introduced quite a long time ago.
To get this sample to build as is you need to target a system version 0.5.2 or before.
Or you copy paste the sources of that library into your project.
Thank you, but I have another error message after I updated library.
spark-dallas-temperature.cpp:442:16: ‘NAN’ was not declared in this scope
In that case you just need to add #include <math.h>
@ScruffR, no error during the compiling.
Thank you!!
But ,it does not work with other reason.
