Error 429 for a Single Request
I am trying to use the following url: (00000 replace the actuals)
https://api.particle.io/v1/serial_numbers/000001032HRPKG?access_token=00000f5588a28a0ecfa5412f19419e52686712eb
and I am getting:
“error”: “rate_limited”,
“error_description”: “Too many requests in a short period of time. Try again later.”
This is a single request
What am I doing wrong?
How do you use this API request ? are you using it with node ? js ? or you just make curl call from terminal ?
We will need some more info about your conf. as with simple HTML/JS and fetch() I don’t have any issue to pull this data:
 <html>
  <head>
 <meta name="viewport" content="width=device-width">
 <meta charset="utf-8"/>
</head>
<style>
 html {
 background: fixed #8c6aec;
 -webkit-background-size: cover;
td:nth-child(even) {
    border-radius: 12px 24px 24px 12px;
    border: 3px solid #E91E63;
    width: auto;
    height: 50px;
    text-align: center;
    background-color: #cddc39;
    color: black;
    font-weight: bold;
td:nth-child(odd) {
    border-radius: 24px 12px 12px 24px;
    width: auto;
    height: 50px;
    text-align: center;
    background-color: #03f48b;
    color: black;
</style>
<body>
<table id="myTable_D1">
<tr>
  </tr>
</table>
<script type="text/javascript">
      var i = 0;
      var ser = "XXXXXXXXXXXXXXXXXXX"; //not display for security
      const accessToken = "XXXXXXXXXXXXXXXXXXX"; //not display for security
      const url_serial = "https://api.particle.io/v1/serial_numbers/" + ser +"?access_token=" + accessToken;
function get_data(){
    fetch(url_serial)
       .then((resp) => resp.json())
       .then(function(data){
           console.log("full data", data);
           draw_table(data);
      .catch(function(error) {
       console.log(error);
function draw_table(data){
  var table_D1 = document.getElementById("myTable_D1");
  var cel_0_D1 = [];
  var cell_D1 = [];
  var row_0_D1 = [];
  if(i>0){
     for(i; i>=0; i--){
        table_D1.deleteRow(i);
  for(var j = 0; j<=3; j++){
     row_0_D1[j] = table_D1.insertRow(j);
  Object.keys(data).forEach(function(key, i) {
      cel_0_D1[i] = row_0_D1[i].insertCell(0);
      cel_0_D1[i].innerHTML = data[key];
      cell_D1[i] = row_0_D1[i].insertCell(0);
      cell_D1[i].innerHTML  = key + " => ";
  i = 3;
setInterval(get_data, 1000);
</script>
</body>
</html>
Curl and Postman
No clue why simple curl can give you this error :man_shrugging:t3: Regarding Postman, are you on free trial ? Maybe you hit API cals limit ?
