I am using an electron with this serial jpeg camera to take a photo every 1 minute and stream the image to the server. But the problem is sometimes the full size image is sent and sometimes the image is sent partially(see image examples attached below). Matter of fact most of the images are incomplete, (Out of every 10 images streamed to the server only 2 are full size) .What could be wrong here. Here is my code
#include "Particle.h"
#define HOST "xxxxx.herokuapp.com"
//CAMERA INITIALIZATION
#define VC0706_GET_FBUF_LEN 0x34
#define CAMERABUFFSIZ 100
uint8_t serialNum;
uint8_t camerabuff[CAMERABUFFSIZ+1];
uint8_t bufferLen;
uint16_t frameptr;
TCPClient client;
int port = 80;
byte incomingbyte;
int a=0x0000,j=0,k=0,count=0;
uint8_t MH,ML;
boolean EndFlag=0;
int coun;
Serial.begin(4800);
Serial1.begin(38400);
delay(1000);
streamImageToServer();
delay(60000);
void streamImageToServer(){
SendResetCmd();
delay(4000);
SendTakePhotoCmd();
delay(1000);
uint16_t jpglen = camFrameLength();
byte a[32];
Serial.println(jpglen);
String end_request = "";
String fileName = "myjpg";
//connect
if (client.connect(HOST,80)) {
Serial.println("conected to the server");
String start_request = "";
start_request = start_request + "--AaB03x" + "\r\n"
+ "Content-Disposition: form-data; name=picture; filename=" + fileName + "\r\n"
+ "Content-Type: image/jpeg" + "\r\n" + "Content-Transfer-Encoding: binary" + "\r\n"+ "\r\n";
end_request = end_request + "\r\n--AaB03x --\r\n";
uint16_t len = start_request.length() + end_request.length()+ (jpglen*32);
client.println("POST /api/images HTTP/1.1");
client.println("Host: xxxxxxxxxxx.herokuapp.com");
client.println("Accept: */*");
client.println("Content-Type: multipart/form-data; boundary=AaB03x");
client.print("Content-Length: ");
client.println(len);
client.println();
client.print(start_request);
while(Serial1.available()>0)
incomingbyte=Serial1.read();
while(!EndFlag)
Serial.println("First time");
j=0;
k=0;
count=0;
SendReadDataCmd();
delay(25);
k++;
if((k>5)&&(j<32)&&(!EndFlag))
a[j]=incomingbyte;
Serial.println(incomingbyte,HEX);
if((a[j-1]==0xFF)&&(a[j]==0xD9))
EndFlag=1;
j++;
count++;
int buffer_size = sizeof(a);
int coun = client.write(a,buffer_size);
delay(1000);
client.print(end_request);
client.stop();
EndFlag = 0;
StopTakePhotoCmd();
/****Util methods*****/
void common_init(void) {
frameptr = 0;
bufferLen = 0;
serialNum = 0;
void sendCommand(uint8_t cmd, uint8_t args[] = 0, uint8_t argn = 0) {
Serial1.write((byte)0x56);
Serial1.write((byte)serialNum);
Serial1.write((byte)cmd);
for (uint8_t i=0; i<argn; i++) {
Serial1.write((byte)args[i]);
uint8_t readResponse(uint8_t numbytes, uint8_t timeout) {
uint8_t counter = 0;
bufferLen = 0;
int avail;
while ((timeout != counter) && (bufferLen != numbytes)){
avail = Serial1.available();
if (avail <= 0) {
delay(1);
counter++;
continue;
counter = 0;
// there's a byte!
camerabuff[bufferLen++] = Serial1.read();
return bufferLen;
boolean verifyResponse(uint8_t command) {
if ((camerabuff[0] != 0x76) ||
(camerabuff[1] != serialNum) ||
(camerabuff[2] != command) ||
(camerabuff[3] != 0x0))
return false;
return true;
boolean runCommand(uint8_t cmd, uint8_t *args, uint8_t argn,
uint8_t resplen, boolean flushflag) {
if (flushflag) {
readResponse(100, 10);
sendCommand(cmd, args, argn);
if (readResponse(resplen, 200) != resplen)
return false;
if (! verifyResponse(cmd))
return false;
return true;
uint32_t camFrameLength(void) {
uint8_t args[] = {0x01, 0x00};
if (!runCommand(VC0706_GET_FBUF_LEN, args, sizeof(args), 9, true))
return 0;
uint32_t len;
len = camerabuff[5];
len <<= 8;
len |= camerabuff[6];
len <<= 8;
len |= camerabuff[7];
len <<= 8;
len |= camerabuff[8];
return len;
void SendResetCmd()
Serial1.write(0x56);
Serial1.write((byte)0);
Serial1.write(0x26);
void SendTakePhotoCmd()
Serial1.write(0x36);
Serial1.write(0x01);
void SendReadDataCmd()
MH=a/0x100;
ML=a%0x100;
Serial1.write(0x32);
Serial1.write(0x0c);
Serial1.write(0x0a);
Serial1.write(MH);
Serial1.write(ML);
Serial1.write(0x20);
a+=0x20;
void StopTakePhotoCmd() {
Serial1.write((byte)0x00);
Serial1.write((byte)0x36);
Serial1.write((byte)0x01);
Serial1.write((byte)0x03);
