Hi All,
I'm trying to figure out how to use SLEEP_NETWORK_STANDBY and SLEEP_DISABLE_WKP_PIN with Deep Sleep - electron with 1.2.0 -beta
Using this:
System.sleep(SLEEP_MODE_DEEP, 300, SLEEP_DISABLE_WKP_PIN, SLEEP_NETWORK_STANDBY);
Or this:
System.sleep(SLEEP_MODE_DEEP, 300, SLEEP_NETWORK_STANDBY, SLEEP_DISABLE_WKP_PIN);
doesn't seem to work. Is there something that I'm missing? Seems like the first one should work.
I'm trying to stop an external watchdog from waking my electron with a rising edge on the WKP pin. The watchdog gets pet every time the firmware runs, and it wakes frequently enough to pet the watchdog without the WKP - BTW the watchdog will use the RST pin to reset the electron if the watchdog is not pet.
