What version does particle identify (in Listening Mode) report now?
Can you also post the output of particle serial inspect?
Hello, thanks for the reply. Yesterday night I tried and tried everything (obviously also switching off and on the electron), and before going to bed quite hungry I checked twice and nothing was working: particle identify was reporting ! serial: Serial timed out. Today, when I went back home from work, Iāve powered the electron and in a few seconds it connected to the cloud. Actually I did nothing. When I put it in listening mode, everything works, firmware is 0.6.4 (correct) and particle serial inspect gives:
Platform: 10 - Electron
Modules
Bootloader module #0 - version 11, main location, 16384 bytes max size
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
System module #1 - version 110, main location, 131072 bytes max size
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
System module #3 - version 110
System module #2 - version 110, main location, 131072 bytes max size
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
System module #3 - version 110, main location, 131072 bytes max size
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
User module #1 - version 3, main location, 131072 bytes max size
UUID: 6B38...F8
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
System module #2 - version 10
User module #1 - version 3, factory location, 131072 bytes max size
UUID: 6B38...F8
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
Well, I am a bit surprisedā¦
So, after checking this commands with the particle cli, I hit the reset button and the electron connected again to the cloud.
I just waited 5 minutes doing nothing else. I hit the reset button again to see if it magically was working fine and everithing went ad the night before: This is the terminal, just called particle identify, the electron cannot enter in listening mode, it just stay white breathing, after 2 minutes breathing Blue, after 30 seconds blinking blue:
I am not sure this is the real listening modeā¦
MG-iMac:~ Marco$ particle identify
MG-iMac:~ Marco$ particle serial inspect
! serial: SyntaxError: Unexpected end of JSON input
MG-iMac:~ Marco$
I finally wrote a user firmware with SYSTEM_MODE(MANUAL); and SYSTEM_THREAD(ENABLED);
Then in the loop: Cellular.listen();
Then, from CLI, calling Particle serial inspect, the response is:
particle identify gives:
Your device id is undefined
Unable to determine system firmware version
Any idea?
Can you try with a serial terminal program and sending the letter v - this should return the firmware version too.
If you want to use functions that require the cellular module with SYSTEM_MODE(MANUAL) you should call Cellular.on() as first step.
Hello, this is the code I flashed inside the electron:
// Test Program
// Enable Threads
// A FuelGauge named 'fuel' for checking on the battery state
FuelGauge fuel;
delay(5000);
Serial.printlnf("Electron initialation done.");
Serial.printlnf("System version: %s", System.version().c_str());
uint32_t freemem = System.freeMemory();
Serial.print("free memory: ");
Serial.println(freemem);
Serial.println("V Bat:" + String::format("%.2f",fuel.getVCell()) + ", SoC: " + String::format("%.2f",fuel.getSoC()));
delay(5000);
//Cellular.listen();
Cellular.on();
Cellular.connect();
if (Cellular.ready()) {
Serial.println("Cellular Ready");
CellularSignal sig = Cellular.RSSI();
Serial.println(sig.rssi);
Serial.println(sig.qual);
Serial.println(sig);
CellularBand band_avail;
if (Cellular.getBandSelect(band_avail)) {
Serial.print("Available bands: ");
for (int x=0; x<band_avail.count; x++) {
Serial.printf("%d", band_avail.band[x]);
if (x+1 < band_avail.count) Serial.printf(",");
Serial.println();
} else {
Serial.printlnf("Bands available not retrieved from the modem!");
if (Particle.connected() == false) {
Serial.println("Connecting to particle cloud");
Particle.connect();
The serial monitor shows:
System version: 0.6.4
free memory: 98760
V Bat:4.08, SoC: 94.97
0
0
0,0
So the system firmware is the 0.6.4
By the way, the serial monitor output stops until the electron start blinking blue.
After the Cellular.connect() call you may want to add a waitUntil(Cellular.ready) or waitFor(Cellular.ready, 60000) call to ensure the connection is established before you proceed and only execute Cellular.on()/Cellular.connect() in case Cellular.ready() != true.
OK, I changed the code:
Serial.println("Cellular is already Ready!");
} else {
Serial.println("Turning ON Cellular and connecting...");
Cellular.on();
Cellular.connect();
waitFor(Cellular.ready, 60000);
} else {
Serial.println("Cellular NOT Ready");
the serial output is:
free memory: 98760
Cellular NOT Ready
0
0
0,0
Then the electron enters in Breathing dark blue, and after 30 seconds, blinking dark blueā¦
After all, I am seriously thinking there is a HW problem with the cellular module⦠It is strange because this electron has always been indoor and it has been used only a couple of days beforeā¦
Obviously your device canāt connect to the cellular network in the allowed 60 seconds.
You could try to increas that to 5 minutes (300000ms).
But maybe itās a problem with the SIM card.
First go to https://console.particle.io/sims to check your SIM is actually active.
If so, it might be an issue with the contact.
For that you can take it out, give the metal bracket on the SIM holder a gentle push to exhert more pressure on the SIM and try again.
If this doesnāt help, you can try to gently pull up the the metal prongs that should make contact with the SIM pads.
Yep, tried everything but the electron is still never flashing green (so not trying to connect to the cellular network).
The sim is active and correctly working if I put it on another electronā¦
To get some extra info on the reason for the issue, you could flash the code provided here and post the output
If this doesnāt reaveal anything you may need to file a support ticket
Well, finally I run the special code for debugging and the serial monitor, after the first check, said:
No reply from Modem ... Sim not inserted.
Even if the sim is inserted correctly and all pins are ok, it seems the cellular modules does not detect the sim. So, as an hardware fault, it is very likely that I will not be able to use this electron any more, except for offline tasks. I am a bit desolate
but this is the real lifeā¦
Thanks for the help, anyway I learned how to find this kind of problems.
I have the same problem, my electron doesn“t connect to the cellular tower and going to listening mode after 30 seconds mor or les, i don“t know why this ocurred.
