Electron Data Usage - URL GET without triggering Particle.function or requesting Particle.variable
Does using the following URL (GET), cost you data usage? My assumption is since its not requesting data via a Particle publish, function or variable. All this would do would be “pinging” the cloud server.
Device ID and Access Token are removed for security reasons.
https://api.spark.io/v1/devices/<device id>/?access_token=<access token>
“id”: “”,
“name”: “Electron”,
“last_app”: null,
“last_ip_address”: “192.168.1.1”,
“last_heard”: “2016-08-27T14:22:49.762Z”,
“product_id”: 6,
“connected”: true,
“platform_id”: 6,
“cellular”: false,
“status”: “normal”,
“pinned_build_target”: “0.5.2”
Here is something I was reading about earlier today that may or may not be helpful for you.
I did ask to see if the “no acknowledge publish” was active now or not.
Yes, the devices endpoint (both accessed directly and through particle list) only queries the database on the cloud server, so it doesn’t incur data charges for the device you’re looking at.
Just for the sake of nit picking, the above would actually be a GET request, so I changed the topic title.
Thanks for catching that, I always get those reversed for some reason! :smile:
Thanks for verifying my assumption!
