I have Micron SPI NAND flash which says its interface is the same as for SPI NOR; maybe that’s already the answer to my problem described below but I am hopeful that I can use SPIFFS or another Particle-ported SPI Flash library. Do you think I stand a chance at getting SPIFFS (or anything) to work on SPI NAND with my Electron? I really like the idea of using embedded FRAM, flash, EEPROM for mechanical resilience as you’ve pointed out before, @peekay123, but need something in the 100+ MB range.
Following this thread and your response to my post a few weeks ago here, I have tried heading down that route but can’t yet get anything other than “Flash init error”. I set my chip select pin in the application.ino using if (flash.begin(D2)) as I’m not using the default CS; all other SPI defaults remain (SCK => A3, MISO => A4, MOSI => A5 for my Electron).
Thanks in advance for any pointers you’re able to offer!
@supscientist, there are key differences between NAND and NOR flash devices. SPIFFS clearly states that it is designed for NOR type flash. However, you can test with the Micron device to see if it works. What device are you proposing to test (part number). Did you modify the Adafruit_TinyFlash.h file with the correct size and IDs? The “flash init” error is specifically related to the Adafruit_TinyFlash code so you need to focus there.
Thanks so much for your help, @peekay123. Just went down the rabbit hole of trying to update particle-cli at its suggestion and lost an hour trying to troubleshoot that, but we’re back! Though it appears I have to compile in the cloud twice using Particle Dev in order to get a new .bin file… I may post about that elsewhere shortly.
Yes, I have seen that SPIFFS is meant for NOR so this might not be a wise approach on my part I’m just really hoping I can find some sort of truly embedded large storage (~1 Gb or bigger) solution.
The part is a Micron MT29F1G01ABAFDSF and I have set Adafruit_TinyFlash.h defines to
I can now get through that flash.begin(D2) call so, at the very least, I’m reading the MAN_ID and DEV_ID. I’m now getting to errno -10010 in test_spiffs() which I see is a SPIFFS_ERR_BAD_DESCRIPTOR. Can’t get past that but I’m trying to play with the CMD_* options in Adafruit_TinyFlash.h. I’m beginning to more deeply appreciate some of the NOR vs. NAND flash differences now as well; maybe I should switch to NOR… Anyway, thanks again, @peekay123!
You should read the SPIFFS docs. The author clearly states the library is not designed for large storage (ie > 128MB) since it is designed for small, resource constrained systems. Besides, performance is greatly affected by the storage size.
For storage that large, you will need to consider a microSD but with a robust locking socket.
Yes, I know, maybe I shouldn’t have used the word “large” which is relative and perhaps meaningless in this context. I have read them. 1 Gb = 128 MB so I thought I’d be fine but maybe the NAND vs. NOR differences will get me here. Micron also sells a 1 Gb serial NOR chip which has a command set closer to what I see in SPIFFS so I’ll test that next just hoped I could kludge it together with NAND & SPIFFS.
It’s a shame that with so many great hardware options there isn’t a software option for larger SPI flash yet! Oh well. Thanks for the really quick and insightful responses.
Other than the higher cost what’s the problem with uSD cards? They have an almost unlimited capacity and are super quick. Plus there is already the working SDFat library for them to get you rolling.
This is an underwater device and the whole PCB needs to be potted in epoxy under pressure. I’m very concerned that epoxy will squeeze in between metal contacts and leave us with failed memory cards and useless products. Maybe it’s just paranoia.
Some of the hacky ways of soldering/reflowing uSDs onto PCBs look promising for small quantities but I was hoping to find a production-scale solution and SPI flash looks sooo close to what I wanted.
I hear you and @peekay123 on going with a solution that just works, though.
I just uploaded a large board to their site to see what I’m looking at pricing wise and it’s not cheap but well worth the cost considering they are fine pitch parts that I would probably not get placed or reflowed correctly.
How quickly did they get them produced for you? How many did you have made?
Feels good to have professionally manufactured designs delivered to your doorstep, doesn’t it
This whole thread is amazing. I have learned so much reading this, and also have more to try and figure out. Lots of advanced stuff going on in this thread for a noob. MicroFab looks like a great source. I think it will push me to redesign my boards using more surface mount components. There is no way I can solder those on my own. Still have more testing to do first.
Thank you for sharing your project and process I have found it very informative.
Cheers and good luck with your new product. Love it.
