Echo Photon Bridge Change RGB LED Colors
I am new to the Particle products and coding in general. I am using the Echo Photon Bridge:
https://github.com/JeremyProffitt/EchoPhotonBridge. I am using this for a lighting project and have managed to get on/off and light percentage to work fine using voice commands with Alexa. I am lost when trying to figure out to get Alexa to change the LED colors. She always says that my LEDs won’t do that. My LED’s are generic 12V RGB common anode units. My electronic circuit is good and has been tested, I’m just not able to work out the code. The example code with the project just shows some code for use with the FastLED library and harware. Any ideas/comments would be welcome.
Thank you,
troutbumoh
My code so far:
#include <EchoPhotonBridge.h>
#include "EchoPhotonBridge.h"
EchoPhotonBridge epb;
#define redPin D0
#define greenPin D1
#define bluePin D2
    pinMode(redPin, OUTPUT);
    analogWrite(redPin, 0, 255);
    pinMode(greenPin, OUTPUT);
    analogWrite(greenPin, 0, 255);
    pinMode(bluePin, OUTPUT);
    analogWrite(bluePin, 0, 255);
    String deviceName = "Desk LEDs";
    epb.addEchoDeviceV2OnOff(deviceName, &functionOnOff);
    epb.addEchoDeviceV2Percent(deviceName, &functionPercent);
int functionOnOff(int device, bool onOff, String rawParameters)
    analogWrite(redPin, (onOff) ? 255 : 0, 255);
    analogWrite(greenPin, (onOff) ? 255 : 0, 255);
    analogWrite(bluePin, (onOff) ? 255 : 0, 255);
int functionPercent(int device, int percent, int changeAmount, String rawParameters)
    analogWrite(redPin, percent * 1, 255);
    analogWrite(greenPin, percent * 1, 255);
    analogWrite(bluePin, percent * 1, 255);
int functionColor(int device, int R, int G, int B, String rawParameters)
    analogWrite(redPin, R);
    analogWrite(greenPin, G);
    analogWrite(bluePin, B);
You are not setting up any function to expose the RGB stuff to the Alexa service.
You only expose OnOff and Percent.
Thank you. I shouldn't try to figure things out when tired. I added the functionColor code to setup and all is well. My new code is below and works nicely.
_________________________________________________________________
#define redPin D0
#define greenPin D1
#define bluePin D2
    epb.addEchoDeviceV2Color(deviceName, &functionColor);
