Alexa skill help
Hello
Im looking for some help with developing a skill using amazon’s aws lambda and skill tools. Following this tutorial (https://medium.com/@thebelgiumesekid/how-to-create-an-alexa-enabled-smart-home-with-particle-photon-part-2-8590314688e8) i was able to get the lambda function up and running and even turn on an led via “Alexa, turn led on” and subsequently turn it off the same way. But now im having trouble implement the same function to turn on two different leds using the same kind of method.
here is the code i code to work with alexa:
#define PIN_LED D4
#define BAUD_RATE 9600
#define LOOP_DELAY 1000
bool isLedOn = false;
void setup_serial(void) {
  Serial.begin(BAUD_RATE);
void setup_pins(void) {
  pinMode(PIN_LED, OUTPUT);
  digitalWrite(PIN_LED, LOW);
void set_led_on(void) {
  digitalWrite(PIN_LED, HIGH);
  isLedOn = true;
void set_led_off(void) {
  isLedOn = false;
bool handler_led(String state) {
  Serial.printf("Event triggered! state: %s\n", state.c_str());
  if (state == "ON") {
    set_led_on();
  } else if (state == "OFF") {
    set_led_off();
  } else {
    return false;
  return true;
void setup_events(void) {
  // Expose the LED state to the cloud
  Particle.variable("isLedOn", isLedOn);
  // Expose a function to change state
  Particle.function("setLed", handler_led);
void setup(void) {
  setup_serial();
  setup_pins();
  setup_events();
void loop(void) {
  Serial.println("looping");
  delay(LOOP_DELAY);
and this is the lambda function which i uploaded for it to work with the led:
const Particle = require('particle-api-js');
const particle = new Particle();
module.exports = {
  setDeviceState(deviceId, state, token) {
    return particle.callFunction({
      deviceId: deviceId,
      argument: state,
      auth: token
    }).then((result) => {
      return result.body.return_value === 1 ? 'ON' : 'OFF';
    }).catch((error) => {
      return null;
  getDeviceState(deviceId, token) {
    return particle.getVariable({ deviceId: deviceId, name: 'isLedOn', auth: token });
im trying to use the same lambda function to implement my own actions and have alexa be able to control two leds in the following code:
const int frontlight = D4; //front light
const int backlight = A2; //back light
  pinMode(frontlight, OUTPUT);
  pinMode(backlight, OUTPUT);
Particle.function("Front-Lights", FrontLights);
Particle.function("Back-Lights", Backlights);
int  FrontLights(String ledCommand) {
    String convertedCommand = ledCommand.toUpperCase();
    if(convertedCommand == "ON FRONT") {
        digitalWrite(frontlight, HIGH);
        return(1);
    } else if(convertedCommand == "OFF FRONT") {
        digitalWrite(frontlight, LOW);
        return(0);
   else {
        return(-1);
int  Backlights(String ledCommands) {
    String convertedCommand= ledCommands.toUpperCase();
    if(convertedCommand == "ON BACK") {
        digitalWrite(backlight, HIGH);
        return(1);
    } else if(convertedCommand== "OFF BACK") {
        digitalWrite(backlight, LOW);
        return(0);
   else {
        return(-1);
Whn i replaced the function names in the lambda function it does nothing. Alexa cant even pick it up. Any help please.
THIS IS THE index.js
const DEVICE_ID = '38003b000d47373334323233';
const Particle = require('./Particle');
exports.handler = async (request, context, callback) => {
  log('DEBUG', `Handler request: ${JSON.stringify(request)}`);
  log('DEBUG', `Handler context: ${JSON.stringify(context)}`);
  const response = await handleRequest(request);
  log('DEBUG', `Response: ${JSON.stringify(response)}`);
  callback(null, response);
function handleRequest(request) {
  let { namespace, name } = request.directive.header;
  switch (namespace) {
    case 'Alexa.Discovery':
      return handleDiscovery(request);
    case 'Alexa.PowerController':
      return handlePowerControl(request);
    case 'Alexa':
      if (name === 'ReportState') {
        return handleStateReport(request);
      return {};
    default:
      log('ERROR', `Unknown namespace ${namespace}`);
      return {};
function handleDiscovery(request) {
  let header = request.directive.header;
  header.name = 'Discover.Response';
  return {
    event: {
      header: header,
      payload: {
        endpoints: [{
          endpointId: 'demo_id',
          manufacturerName: 'Wonka Chocolate Factory',
          friendlyName: 'Particle Device',
          description: 'Particle Device',
          displayCategories: ['SWITCH'],
          capabilities: [
              type: 'AlexaInterface',
              interface: 'Alexa',
              version: '3'
              interface: 'Alexa.PowerController',
              version: '3',
              properties: {
                supported: [{
                retrievable: true,
                proactivelyReported: false
async function handlePowerControl(request) {
  log('DEBUG', 'Triggered PowerControl');
  const token = getParticleTokenFromRequest(request);
  let stateToSet;
  // Set correct state based on the Alexa directive
  if (request.directive.header.name === 'TurnOn') {
    stateToSet = 'ON';
  } else {
    stateToSet = 'OFF';
  // Set the state on the device, also get the actual state (should be the same)
  const actualState = await Particle.setDeviceState(DEVICE_ID, stateToSet, token);
  let { header, endpoint } = request.directive;
  header.namespace = 'Alexa';
  header.name = 'Response';
  const returnContext = {
    properties: [ {
      namespace: 'Alexa.PowerController',
      value: actualState,
      timeOfSample: (new Date()).toISOString(),
      uncertaintyInMilliseconds: 0
  const response = {
    context: returnContext,
    event: {
      header: header,
      endpoint: endpoint,
      payload: {}
  log('DEBUG', `Set State: ${JSON.stringify(response)}`);
  return response;
async function handleStateReport(request) {
  header.name = 'StateReport';
  const stateBool = await Particle.getDeviceState(DEVICE_ID, token);
    properties: [{
      value: stateBool.body.result ? 'ON' : 'OFF',
      timeOfSample: stateBool.body.coreInfo.last_heard,
  const response = {
    event: {
      header: header,
      endpoint: endpoint,
      payload: {}
  log('DEBUG', `State Response: ${JSON.stringify(response)}`);
  return response;
function getParticleTokenFromRequest(request) {
  // request.directive.endpoint.scope.token OR request.directive.payload.scope.token
  const tokenData = (request || {}).directive || {};
  return ((tokenData.endpoint || tokenData.payload || {}).scope || {}).token;
function log(type, value) {
  console.log(`${type}: ${value}`);
Just to state the obvious.
In your working example your lambda explicitly states the endpoint (Particle.function() name setLed to hit) and the two possible states (ON and OFF).
In your second lambda, none of that is present AFAICT (neither of these Front-Lights, Back-Lights, ON FRONT, OFF FRONT, ON BACK nor OFF BACK).
For one, there is no need to be redundant with FRONT and BACK in the function name and the function parameter. Either use it in the name (preferable for the lambda) or in the parameter (preferred when calling via console or a mobile app).
Hey buddy thank you so much,
so i got it to work with my function but i cant get it to work by callung the function name. I have to say “Particle” each time and im not able to add more than one function at a time. Any help please. I had to edit the code to reflect one function as shown below
const int led1 = D4;
const int led2 = A2;
const int LED_PIN = D7;
  pinMode(led1, OUTPUT);
  pinMode(led2, OUTPUT);
digitalWrite(LED_PIN, LOW);
Particle.function("Front-Lights", ledRemote);
//Particle.function("Back-Lights", ledRemote1);
int ledRemote(String state) {
    if(state == "ON") {
        digitalWrite(led1, HIGH);
        return(1);
    } else if(state == "OFF") {
        digitalWrite(led1, LOW);
        return(0);
   else {
        return(-1);
and the Particle.js file to this
module.exports = {
      deviceId: deviceId,
      argument: state,
      auth: token
      return null;
    return particle.getVariable({ deviceId: deviceId, name: 'Front-Lights', auth: token });
any way to call alexa by its function name and invoke the state to on/off by that function specically as in the first code i had ?
