I was experiencing some problems with TCPServer and TCPClient last night. Running the simple example from the spark docs was causing my core to go into the dreaded red, blinking SOS of death with a “hard fault” code.
I eventually figured out that I could always get the code to hit this hard fault by connecting to the core using the telnet protocol. However, when I use raw TCP the program executes just fine, with no crashes seen yet. The spark code I’m using is below. And I’m using putty as the client.
To be clear: I fully expect that connecting to this program using telnet should cause all kinds of weirdness since the telnet protocol includes extra goo along with the text. But I can’t see how this should cause a fault in the code sample. It really looks like a bug in the spark TCP code.
Anyway, it looks like there have been problems with the spark TCP stack for some time now, so I figured I’d post this in case it helps debugging – since it’s a very easy and straightforward way to repro a hard fault.
And… before anyone starts theorizing about how the code below might be causing the fault… I should point out that, when connecting to this using telnet, the spark never seems to send out anything after “Connected to Spark!” So it doesn’t look like it’s ever getting to the client.write(client.read()) loop.
#include "application.h"
TCPServer server = TCPServer(23);
TCPClient client;
char addr[16];
server.begin();
IPAddress localIP = WiFi.localIP();
sprintf(addr, "%u.%u.%u.%u", localIP[0], localIP[1], localIP[2], localIP[3]);
Spark.variable("Address", addr, STRING);
client = server.available();
if (client.connected()) {
client.println("Connected to Spark!");
client.println(WiFi.localIP());
client.println(WiFi.subnetMask());
client.println(WiFi.gatewayIP());
client.println(WiFi.SSID());
client.println(">");
while (client.connected()) {
while (client.available()) {
client.write(client.read());
