I’m having some troubles once again with the charging circuit of the E-Series module on my pcb.
What I’m seeing now after purchasing a new higher current supplying charger (Insignia 2.4A usb charger), I’m getting unpredictable charging rates. Im still using your PMIC settings that you provided shown below:
#include "Particle.h"
// Resets bq24195 charge controller
void writeRegister(uint8_t reg, uint8_t value);
// REG00 Input Source Control Register
writeRegister(0, 0b00110000);
// REG01 Power-On Configuration Register
writeRegister(1, 0b00011011);
// REG02 Charge Current Control Register
writeRegister(2, 0b01100000);
// REG03 Pre-Charge/Termination Current Control Register
writeRegister(3, 0b00010001);
// REG04 Charge Voltage Control Register Format
writeRegister(4, 0b10110010);
// REG05 Charge Termination/Timer Control Register
writeRegister(5, 0b10011010);
// REG06 Thermal Regulation Control Register
writeRegister(6, 0b00000011);
// REG07 Misc Operation Control Register Format
writeRegister(7, 0b01001011);
void writeRegister(uint8_t reg, uint8_t value) {
// This would be easier if pmic.writeRegister wasn't private
Wire3.beginTransmission(PMIC_ADDRESS);
Wire3.write(reg);
Wire3.write(value);
Wire3.endTransmission(true);
I’m monitoring the current to the single cell lipo battery through a voltmeter and able to see the current change when it is charging. The most current I see going to the battery to charge it is when the E-series is set to sleep (I call this in my code: System.sleep(D4,FALLING)
and a few devices are turned off through mosfets on the pcb that are being supplied power through the particle’s 3V3 line. After this is called, the battery is getting about 340 mA which is ok but still not anywhere near what the charger would be able to supply and what the current settings are set to from your suggested register reset settings from my previous message in this post.
When the device comes out of sleep mode, the battery is no longer charging, but instead it is supplying current to the E-series module. This is with the high current capacity charger connected to the usb (pins 3,13,and 14 on the E-series). The rest of my circuit that the E-series module is part of pulls between 230 mA and 400 mA which is all being supplied through pin 9 of the module (3V3) which is well under the max that the 3V3 can supply (800mA). I’ve been referencing the datasheet for the BQ24195 IC but is there a good example for how to configure the PMIC using Particle’s built in functions?
The odd thing is that when I connect the usb instead to my PC, i can actually charge the battery when it is not in sleep mode. It is able to supply ~180 mA to the battery while also supplying power to the rest of my circuit. I don’t understand why the PC is able to supply more current than the actual high current charger!
Very confused…
Craig
