Draw color bitmap - Adafruit_mfGFX
I’m trying to draw a color bitmap with the Adafruit_mfGFX and Adafruit_ST7735 lib which I think @peekay123 ported??
I used this link to convert the image to a color bitmap array, but the libary only has a function to draw a bitmap where you have to tell it the color to use. I was hoping there was a function like drawBitmap256K and it would use the colors in the bitmap array?? Or is there some other lib to use to accomplish this?
static const unsigned char flameon2[]{…};
Current function:
drawBitmap(int16_t x, int16_t y, const uint8_t *bitmap, int16_t w, int16_t h, uint16_t color)
Would like:
drawBitmap256K(uint8_t x, uint8_t y, uint8_t w, uint8_t h, const uint8_t *bitmap)
John
In my Adafruit_HX8357 library (on Web IDE) you can find a demo called SPITFTBITMAP that contains a void bmpDraw(char *filename, uint8_t x, uint16_t y) which takes a bitmap file from SD and pushes it to the display.
If you strip this down to use your bitmap array instead of a file, you might have what you’re looking for.
The function I borrowed of the original SPITFTBITMAP demo from Adafruit :wink:
@ScruffR, I’ll see if I can do that. My c skill are way rusty and I have never worked with bitmaps before so this could be interesting :smile:
If you need some assistance, you know where to find us :smile: - it shouldn’t be too hard to understand and alter for your needs.
Be confident :+1:
@xcode, did you ever get something working ?
Sorry missed this. No, I couldn’t quite figure it out.
