Digole 1.8" TrueColor OLED - Color Bitmap
Hi all,
does anyone have a Digole 1,8" OLED?
I have a problem using the function drawBitmap256(x,y,w,h, const uint8_t *Bitmap).
Every time I use the 256 function the :spark: Core blinks magenta (flashing) then it stops blinking a short time and returns directly with a white breathing (normal ops). It run directly in the main loop. No setup will be executed.
If I remove the 256 and run only drawBitmap() then it works but I have only B/W images. Flashing magenta, starts flashing green (connecting to network/cloud) breathing white setup run.
I draw the pictures with: http://pixieengine.com/pixel-editor and convert it with the Digole “convert picture to c code” converter. Any ideas why it crashes with color bitmaps?
#define _Digole_Serial_SPI_
#include "DigoleSerialDisp.h"
DigoleSerialDisp digole(A2); //SPI
const uint8_t myTest[] =  {....}
    digole.begin();
    digole.disableCursor();
    digole.clearScreen();
    digole.drawBitmap(0,2,32,32, myTest);
void loop {
digole.print("Hello World");
Could you quickly check the RAM usage?
How can I do that? Sorry don´t know.
In the Web IDE, when you compile, at the error output area, you will see a !
Click on that and you should see the memory usage display. if you don’t just add in a SPACE or some movement to your code and compile again
I have one of those displays… can you post your full problem code? You can format it nice like this :wink:
```cpp
// put code in here
@kennethlimcp: I got only a “Ready.” No (i)
Sorry :smiley:
@BDub
Libfiles: DigoleSerialDisp.cpp and DigoleSerialDisp.h
.ino File:
const uint8_t myBit[] = {
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff
,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xff,0xff,0xff,0xff,0xff
,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xff,0xff,0xff,0xff,0xff,0xff
,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xff,0xff,0xff,0xff,0xff,0xff,0xff
,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff
,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff
,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff
,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff
,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff
,0xff,0xff,0xff,0xff,0xff,0xff,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff
,0xff,0xff,0xff,0xff,0xff,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff
,0xff,0xff,0xff,0xff,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff
,0xff,0xff,0xff,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff
,0xff,0xff,0xff,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff
,0xff,0xff,0xff,0xc0,0xc0,0xc0,0xc0,0xc0,0xc0,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff
,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff };
    digole.begin();
    digole.drawBitmap256(0,0,32,32, myBit);
    delay(20000);
    digole.print("Greetings Earthling");
    delay(20000);
@kennethlimcp: When I use compile and download the bin file is 75,5kb
I guess we have to wait for @BDub to be up and running before getting a reply. These aren’t the area i have been messing with :wink:
Not the problem, thanks anyway @kennethlimcp
@clyde, I also have one of those displays and ran your code, unmodified without any problems! I used the Spark CLI to compile and used @timb’s repo for the code. It displayed the logo in color and then gave me a proper earthling greeting :stuck_out_tongue:
How did you create/compile your code?
This is maybe a silly question, could the power draw be spiking or something during that write? A long-white RGB led on core startup can indicate the core is having a problem initializing the cc3000, and I’ve seen that happen with bad USB cables, or when underpowering the core.
David
@Dave, interesting point and I forgot to ask!
@clyde, how are you powering your Digole. From the Vin pin or one of the 3.3V pins?
@Dave The OLEDs VCC is powered with VIN the USB cable is the one that comes with the core.
@peekay123: :spark: WebIDE
The only time I've seen it flash magenta is when you reprogram the Core OTA.
Perhaps a video of the behavior would be appropriate if there are no issues with the power connections.
Ok got it to work
  1. Changed the USB cable
  2. Changed the code, because I wanted to use that image 2nd time. But that did not work.
    Maybe not enough memory.
B/W works fine… Thx for testing and all the help.
Video
@peekay123, @BDub, @kennethlimcp, @Dave Should run :wink: enjoy!
That’s sweet! Nice job! :slight_smile:
@clyde, OMG I think I’m going to cry :stuck_out_tongue:
Awexome @clyde! Glad to have helped!
