Does EEPROM.put support power-fail recovery?
@rick
According to document EEPROM.put should support power-fail recovery.
https://docs.particle.io/reference/device-os/firmware/photon/#put-
If the Photon loses power before the write finishes, the partially written data will be ignored.
But I did not find any algorithm do power-fail recovery work,for example I call EEPROM.put(a float number) and power off when only two byte write back to flash,when I read this float number when power on again something will go wrong.
    // Writes a new value for a byte of EEPROM
    // Performs a page swap (move all valid records to a new page)
    // if the current page is full
    void put(Index index, Data data)
        writeRange(index, &data, sizeof(data));
    // Write each byte in the range if its value has changed.
    void writeRange(Index indexBegin, const Data *data, uint16_t length)
        // don't write anything if index is out of range
        Index indexEnd = indexBegin + length;
        if(indexEnd > capacity())
            return;
        // Read existing values for range
        std::unique_ptr<Data[]> existingData(new Data[length]);
        // don't write anything if memory is full
        if(!existingData)
            return;
        Address writeAddressBegin;
        // Read the data and make sure there are no previous invalid
        // records before starting to write
        bool success = readRangeAndFindEmpty(getActivePage(),
                existingData.get(), indexBegin, length, writeAddressBegin);
        // Write records for all new values
        success = success && writeRangeChanged(writeAddressBegin, indexBegin, data, existingData.get(), length);
        // If any writes failed because the page was full or a marginal
        // write error occured, do a page swap then write all the
        // records
        if(!success)
            swapPagesAndWrite(indexBegin, data, length);
    // Write new records backwards in Flash. This ensures data
    // consistency if writeRange is interrupted by a reset since reads
    // stop at the first non-valid record.
    bool writeRangeChanged(Address writeAddressBegin, Index indexBegin, const uint8_t *data, const uint8_t *existingData, uint16_t length)
        bool success = true;
        // Count changed values
        uint16_t changedCount = 0;
        for(uint16_t i = 0; i < length && success; i++)
            if(existingData[i] != data[i])
                changedCount++;
        // Write all changed values, backwards from the end
        if(changedCount > 0)
            Address writeAddress = writeAddressBegin + changedCount * sizeof(Record);
            Address endAddress = getPageEnd(getActivePage());
            // There must be an empty record after the position where the
            // last record will be written to act as a separator for the
            // valid record detection algorithm to work well
            if(writeAddress < endAddress)
                Record separatorRecord;
                store.read(writeAddress, &separatorRecord, sizeof(separatorRecord));
                success = separatorRecord.empty();
                    Index index = indexBegin + i;
                    writeAddress -= sizeof(Record);
                    success = success && writeRecord(
                            writeAddress, endAddress, Record(index, data[i]));
        return success;
One Record save one byte,So only one byte can be recovery after power-fail issue.Any type for example float more than one byte can not recovery after power-fail issue.Am I right?
@ming I am using EEPROM with a Photon for exactly this purpose.
I do 4 things which make EEPROM easy to use:
  1. A Struct with all the data
struct mySettings
    byte    resumeFlag;
  1. create eeprom settings object called param mySettings param; so that if I want to use the values they are param.resumeFlag
  2. functions to put and get the struct from EEPROM
void putParameters()
    int addr = 0;
    EEPROM.put(addr, param);
  1. Take care to initialise the values when initially started, e.g. a setup
I do the same.I am worry about power-fail recovery.
Reference Document:
The object data is first compared to the data written in the EEPROM to avoid writing values that haven't changed.
But I do not think particle SDK source code support this feature
Source code:
@ming You have 2 strategies in my opinion:
  1. Do regular EEPROM put of the data you need to do a “resume” after power restored. Then there is the issue that your last commit of recovery data may have been a while ago but writing only when changes means you could call this every loop - assuming you are changing recovery values with less frequency.
  2. Catch the system event for power outage/brownout and do a put to EEPROM at that point (of course this may not complete).
A hardware solution is to have a coin cell battery powering VBAT and to use retained RAM to store your recovery data. Have you considered this?
Yes.
But current issue is:
According to Particle Document EEPROM.put support power-fail recovery.
According to Particle SDK source code EEPROM.put do not support power-fail recovery If I am right.
Suggest you PM Julian Vanier or Rick - there are numerous cases where the documentation is not 100% correct.
Thanks.
