Is it possible to permanently disable charging on the Boron? I understand there is an OS API call to disable charging but I would prefer to disable at the hardware or firmware level.
Thanks Jared. Is what you are suggesting different than the pmic.disableCharging(); command? I am not familiar with writing to the bq24195L
Yup, that should do it. I haven’t tested it myself yet.
