Hi, I am experimenting with one of my motion sensor https://store.ncd.io/product/lis3dhtr-3-axis-accelerometer-digital-output-motion-sensor-i2c-mini-module/ by using the different mode which help me to use much lower power, I was thinking which mode in this sensor which help me as follows :
- To power on the sensor some certain time and monitor the parameters.
- If everything remains same it will power off for specific time.
- The sensor power will be remain off for very few time only.
Main to send sensor to sleep mode for few miliseconds, and main important thing I need is to store data of sensor on azure cloud database and also store the record in database of whenever the sensor goes in offline mode.
Any expertise suggestion to make this thing happen will be very helpful
Note: The sensor is using the IC - LIS3DHTR for sensing 3 axis motion
