I am utilizing a Boron to monitor AC power status for a server room to detect power outages.
The system worked well on firmware 1.1.1; however, I upgraded to 1.4.4 and it is no longer detecting power status as before.
@rickkas7, is it possible that the DiagnosticsHelperRK library is not compatible with this version?
See the following link for my build: https://go.particle.io/shared_apps/5e149d8a8cadfc0005011542
Thank you!
