DFU-util udev rules
I’m wondering if any awesome people in our community knows how the udev rule should be for dfu-util in linux
Managed to compile dfu-util 0.8 on Raspbian for Rpi V2 but sudo is required to do stuff. Would love to not use sudo whenever possible.
Thanks~ :smiley:
I needed this too, so I created this udev rules file to enable use of particle flash --usb without sudo.
Credits to the creator of the Teensy board (Paul Stoffregen - [Name added by ScruffR]) for the basis of this udev file.
Here’s another good trick from the Teensy creator to prevent having the serial port change device each time you plug the device in:
If using USB Serial you get a new device each time (Ubuntu >9.10)
eg: /dev/ttyACM0, ttyACM1, ttyACM2, ttyACM3, ttyACM4, etc
   apt-get remove --purge modemmanager     (reboot may be necessary)
This was very helpful. Thanks!
Hello jvanier,
I have copied this file /etc/udev/rules.d directory. It is named it as 50-particle.rules. When I set my photon in DFU mode(blinking yellow) and typed dfu-util -l in the terminal. I am getting
dfu-util: Cannot open DFU device 2b04:d006. It gets opened if I use sudo. I even restarted my machine, plugged in and plugged back USB but it’s still the same
I am running arch linux.
Thanks for your time
I’ve never used arch. I’m not sure if there’s a difference there. Can you search if udev rules are stored somewhere else for your system?
[UPDATE]: changing the file name to 99-particle.rules fixed it for me.
In arch linux, the udev rules are stored under /etc/udev/rules.d
