Photon: dfu-util on Ubuntu fails to flash
Hi there,
I have setted my Photon to DFU mode:
https://docs.particle.io/guide/getting-started/modes/photon
And I am trying to flash this blink example (session Compile Locally, Flash Locally - Over USB):
https://learn.sparkfun.com/tutorials/photon-development-guide/all
But my Photon always got back to blinking blue.
Any help/suggestions?
My versions are:
$ uname -a
Linux 3.16.0-62-generic #83~14.04.1-Ubuntu SMP Fri Feb 26 22:52:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
$ particle help
Welcome to the Particle Command line utility!
Version 1.11.0
$ dfu-util -V
dfu-util 0.9
$ dfu-util -v -v -d 2b04:d006 -a 0 -i 0 -s 0x080A0000:leave -D blink.bin
dfu-util 0.9
Opening DFU capable USB device…
ID 2b04:d006
Claiming USB DFU Interface…
Setting Alternate Setting #0
dfuIDLE, continuing
Memory segment at 0x08000000 3 x 16384 = 49152 ®
Memory segment at 0x0800c000 1 x 16384 = 16384 (rew)
Memory segment at 0x08010000 1 x 65536 = 65536 (rew)
Memory segment at 0x08020000 7 x 131072 = 917504 (rew)
Downloading to address = 0x080a0000, size = 2936
Download [ ] 0% 0 bytesErasing page size 131072 at address 0x080a0000, page starting at 0x080a0000
Poll timeout 50 ms
Poll timeout 0 ms
Download from image offset 00000000 to memory 080a0000-080a0b77, size 2936
Poll timeout 50 ms
Poll timeout 0 ms
File downloaded successfully
Poll timeout 50 ms
Poll timeout 0 ms
dfu-util: Error during download get_status
$ particle flash --usb blink.bin
running dfu-util -l
Found DFU device 2b04:d006
checking file blink.bin
spawning dfu-util -d 2b04:d006 -a 0 -i 0 -s 0x080A0000:leave -D blink.bin
dfu-util 0.9
ID 2b04:d006
dfuIDLE, continuing
Download [=========================] 100% 2936 bytes
Download done.
Error writing firmware…dfu-util: Invalid DFU suffix signature
The above means that it worked. You can safely ignore the dfu-util: Error during download get_status error as that is not a real error.
If your device is still blinking dark blue, then it does not have WiFi credentials yet.
@bko,
Yes, I have tryed this too, but my Photon got back to blinking magenta (Safe Mode) and the led D7 did not blink.
How did you run make? Did you include the platform option so it knows to build for a Photon? If not, that would give you the kind of thing you are seeing.
Try this with your device in dfu mode:
make PLATFORM=photon APP=blink program-dfu
@bko,
Yes, as follow below:
cd firmware/main
make PLATFORM=photon clean all
And after that:
  1. make PLATFORM=photon APP=blink program-dfu
  2. particle flash --usb blink.bin
  3. dfu-util -v -v -d 2b04:d006 -a 0 -i 0 -s 0x080A0000:leave -D blink.bin
But the result is the same
This command, with the part in dfu mode, compiles the blink APP and downloads it over dfu, so all the other commands are not needed.
@bko,
I have tried with another device Photon that I have, it flash normally and worked fine the example “blink”, and does not returned any error like “dfu-util: Error during download get_status”.
Do you know the reason why that happened?
It might have more recent software that implements the get_status command in DFU mode.
That issue was closed last Sept. in this change:
