Dfu-util: Last page at 0x08118913 is not writeable error when downloading code to photon
Hello,
I have an issue with photon not downloading the code in dfu-util mode. My build setup is as follows:
  1. Local build using the following make command executed in firmware/main.
    make APPDIR=/<path_to_project>/src PLATFORM=photon MODULAR=n DEBUG_BUILD=y PARTICLE_DEVELOP=1 all
The src folder contains all the .h and .cpp files. This compiles fine and produces a folder named ‘target’ in the src folder. So far so good.
  1. Now I kept the photon in dfu-util mode and executed the following command.
dfu-util -d 0x2B04:0xD006 -a 0 -s 0x80A0000:leave -D src.bin
Here is the log from terminal:
dfu-util 0.8
Opening DFU capable USB device…
ID 2b04:d006
Claiming USB DFU Interface…
Setting Alternate Setting #0
dfuIDLE, continuing
Downloading to address = 0x080a0000, size = 493844
dfu-util: Last page at 0x08118913 is not writeable
I was able to download the program through dfu-util before. Now I get this error. Any insights would help?
Thank you
Dheeraj
Monolithic firmware (MODULAR=N) should be flashed to 0x8020000 because it takes the place of both system and user firmware.
Thank you. It worked!
