Device Name in Webhook
Is there any way to do this? I’m able to get the Device ID which also works totally fine, but being able to use my own set-up names for my devices would be a lot more convenient.
I’m using Electrons.
@Vitesze, you might want to do a doc search first next time :wink:
https://docs.particle.io/reference/firmware/electron/#get-device-name
Similar answer here
Please don't double post questions. It ties resources for no good reason.
Especially since we both just refered you to the docs which should have been the first place to look for.
If you use the search field in the docs you get this
which will lead you exactly to the place we both linked you too
