Device ID over serial line
I am setting up sensors with the Particle Photon. I would like to identify them uniquely from the serial connection. At the moment, my code on the Particle Photon outputs:
timestamp,temperature,acceleration
I want to include the device ID as a filed. Particle published a way to query the device ID and I would like to print it from within the firmware code to the serial line.
Is it possible to print a device ID on the serial line?
It’s accessible from the device itself as well, and returns a String object: https://docs.particle.io/reference/device-os/firmware/argon/#deviceid-
You’re then free to do with that as you please.
Thanks! That solved my problem and I added an answer to the original question on StackOverflow, which also asked about the SparkFun OpenScale.
