Hello guys,
I need someone to make a prototype with IOT system. I use sensors and i need lora puce to send data to a cloud by using gateway. Your help is to design pcb card and.
thanks
@mourtalla, does you design use a Particle device such as a Boron or Photon 2?
hello sir,
no i don’t design with it , i used arduino and lora. Bit now i need to have a pcb for my mvp
@mourtalla, this is a Particle devices forum and some members have paired the cellular Boron, acting as a gateway, with Lora transceivers. However, your MCU is different and you may want to look at other forums for help, such as KiCad or paid-for service on Freelancer.
