Hi Community,
I’m planning to transition from E404 to B404x. I deploy on the actual eval board which I encase in a thermal epoxy brick and bring out wires for RGB, I/O’s, etc. I have some questions I can’t find in the documentation–
- I’m using a converter to step down to 12V but I think it could slightly creep above 12V. Is there any tolerance if voltage exceeds 12V?
- On ID Num 24 in documentation what are power jumpers for? Is it just useful for troubleshooting?
- If you pin out the RGB / status LEDs (to external, off board LEDs) does that kill the on-board LEDs, or will both light?
