Let’s say i update an application that had defined the maximum number of Spark.variables and the maximum amount of published events. Now i remove some of the variables and event names from my application and add new ones to the application How do I insure that the particle cloud has deleted the prior names so I am clear to create new variable names.
Or, for another example, let’s say there is a limit of 6 published events and I create app1event1 through app1event6 as the names. Now I decide to re flash my Photon with a new app with event names app2event1 through app2event6. Before I start fflashing app2 it would seem I need to tell the Particle cloud that I am no longer using the app1event names.
I am concerned that without removing names, when I exceed the maximum variable names or events that I will get a Failure to set the variable or failure to publish the event because I have too many names.
