Getting this message when Photon connects to Local Cloud. The Photon is connecting but its getting others errors. Any ideas?
Connection from: ::ffff:192.168.1.29, connId: 1
CryptoStream transform error TypeError: Cannot read property 'length' of null
on ready { coreID: 'DEVICE_ID',
ip: '::ffff:192.168.1.29',
product_id: 6,
firmware_version: 65535,
cache_key: '_0' }
Core online!
Coap Error: Error: Invalid CoAP version. Expected 1, got: 3
routeMessage got a NULL coap message { coreID: 'DEVICE_ID' }
CryptoStream transform error Error: error:06065064:digital envelope routines:EVP_DecryptFinal_ex:bad decrypt
Coap Error: Error: Invalid CoAP version. Expected 1, got: 0
I tried refreshing the keys on the local cloud server, but it appear to result in the same message:
refreshing local keys:
$ particle config identify
Current profile: local
Using API: http://192.168.1.21:8080
Access token: ACCESS_TOKEN
(DFU Mode)
$ cd spark-server/
spark-server $ particle keys server default_key.pub.pem 192.168.1.21
running dfu-util -l
Found DFU device 2b04:d006
Apparently I didn't find a DFU device? util said dfu-util 0.8
Deducing device DFU version from functional descriptor length
Found Runtime: [05ac:8289] ver=0103, devnum=5, cfg=1, intf=3, alt=0, name="UNKNOWN", serial="UNKNOWN"
Found DFU: [2b04:d006] ver=0200, devnum=6, cfg=1, intf=0, alt=1, name="@DCT Flash /0x00000000/01*016Kg", serial="00000000010C"
Found DFU: [2b04:d006] ver=0200, devnum=6, cfg=1, intf=0, alt=0, name="@Internal Flash /0x08000000/03*016Ka,01*016Kg,01*064Kg,07*128Kg", serial="00000000010C"
checking file default_key.pub192_168_1_21.der
spawning dfu-util -d 2b04:d006 -a 1 -i 0 -s 2082 -D default_key.pub192_168_1_21.der
dfu-util 0.8
ID 2b04:d006
Claiming USB DFU Interface...
Setting Alternate Setting #1 ...
dfuIDLE, continuing
DfuSe interface name: "DCT Flash "
Downloading to address = 0x00000822, size = 1024
Download [=========================] 100% 1024 bytes
Download done.
File downloaded successfully
Okay! New keys in place, your device will not restart.
spark-server $ cd core_keys/
core_keys $ particle keys save DEVICE_ID
This file already exists, please specify a different file, or use the --force flag.
core_keys $ particle keys save DEVICE_ID --force
running dfu-util -l
running sudo dfu-util -d 2b04:d006 -a 1 -s 34:612 -U DEVICE_ID.der
Password:
running openssl rsa -in DEVICE_ID.der -inform DER -pubout -out DEVICE_ID.pub.pem
Saved!
(Reboot Photon)
(Terminal Local Cloud)
$ cd spark-server/
$ node main.js
Loading user EMAIL_ADDR
connect.multipart() will be removed in connect 3.0
visit https://github.com/senchalabs/connect/wiki/Connect-3.0 for alternatives
connect.limit() will be removed in connect 3.0
Starting server, listening on 8080
static class init!
found DEVICE_ID
Loading server key from default_key.pem
set server key
server public key is: -----BEGIN PUBLIC KEY-----
XXX
-----END PUBLIC KEY-----
Your server IP address is: 192.168.1.21
server started { host: 'localhost', port: 5683 }
(After Photon reboots and comes back online)
(From Curl)
$ curl http://192.168.1.21:8080/v1/devices/?access_token=API_TOKEN
"id": "DEVICE_ID",
"connected": true
