Trying to set up 2 photons for an upcoming job, one setup went perfectly fine, cloud connected, breathing cyan. When trying to set up my second, I get: ERROR could not communicate with photon cloud. I’ve tried closing the app completely and restarting, restarting my phone, disconnect and reconnect to my wifi, nothing helps. Any ideas?
If you want to get the device set up to get unblocked, I’d use CLI.
That’s what I’m doing now, but I don’t always have access to a computer on site somewhere so I’m wondering what may be going on and how to resolve it.
We’d need to know more about that Photon in question.
- What does
particle serial inspect
tell you about it? - What is the SSID exposed by it when putting it in Listening Mode?
Photon SSID: Photon-P4M7X5
Particle Serial Inspect:
Platform: 6 - Photon
Modules
Bootloader module #0 - version 311, main location, 16384 bytes max size
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
System module #1 - version 1213, main location, 262144 bytes max size
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
System module #2 - version 204
System module #2 - version 1213, main location, 262144 bytes max size
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
User module #1 - version 5, main location, 131072 bytes max size
UUID: C78CA6A0F3FCC1108BE3888130FE3C936D03A6156FFB4937F82EA18ACAD7413D
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
System module #2 - version 23
User module #1 - version 5, factory location, 131072 bytes max size
Integrity: PASS
Address Range: PASS
Platform: PASS
Dependencies: PASS
I found the problem, the photon would connect to the cloud but wouldn’t show up in my devices. When I try to claim it manually, it says I’m over my device limit. I took care of that, but it would have been nice to get that alert through the app rather than the error it showed.
Hitting the device limit is rare, but we should still have a better experience there, no doubt. Thanks for the feedback, @Mjones!
By the time I finish cleaning everything up, I won’t be close to that. I had several damaged in lightning, flood, or something else and never removed them from my account.
