Hello
We’ve developed a board based quite closely on the Particle Electron (using the same micro).
We’ve used a couple of micro pins that weren’t run out to headers on the Electron and hence haven’t been assigned a high level pin name (e.g D5)
I’ve read through the HAL files in the firmware, namely:
hal/src/stm32f2xx/pinmap_hal.c
hal/inc/pinmap_hal.h
I think I’ve got a reasonable idea what’s going on, however I’m unsure what the ‘by the book’ way is to deal with this.
Should we create a custom PLATFORM_ID for our product and compile locally using modified pinmap.hal files?
Or is it simpler to create a file within our application that patches in the required HAL code for the new pins?
